Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
3D carbon fiber vinyl wrap
Old Sep 29, 2011 | 04:02 AM
tpham858's Avatar
Lightbulb 3D carbon fiber vinyl wrap
Hey there, has anyone tried to wrap their cars with the new 3D vinyl carbon fiber yet? I bought a huge roll of 5'x6'. I'm going to wrap the interior, I did a test run with the console and it looks pretty good. but letting it sit a few days, it started coming up at the bends. I'm going to try and heat shrink it back and it might stay but it should be fine when installed just wondering if anyone else has tried it. I'll post pics soon.
Old Sep 29, 2011 | 11:32 AM
no_luck's Avatar
this just sounds like a horriable idea.. cause if the sun eats away at its going too look like *** and if it doesnt **** up from that and it starts to melt the glue an dhsit then you ganna have a fucked up dash.. or what ever else you wrapped
Old Oct 2, 2011 | 11:10 AM
Jhereg's Avatar
www.signaturetile.net
I did several interior pieces. Gauge trim and cover, radio surround, shifter surround and wibndow switch plate. To be honest, It lost it's appeal pretty quick and I pulled it all off and just painted them flat black. I had the same problem with sections coming up here and there and it just never looked great. Maybe pros have some tips on keeping it down better at the edges/corners.
Old Oct 29, 2011 | 07:03 PM
ultima 1's Avatar
vinyl wrap
Sorry the vinyl wrap didn't work.
I have seen interior cf vinyl work done and loved it. It was worth the try.
A topic variation, I saw a car exterior done completely in a wrap and was very impressed. I googled vinyl wrap and read a few things: it seems u get what u pay for. As usual, some of the wraps don't turn corners, as they are for flat panels only!
A friend has a vinyl wrap business here in california for big trucks and i plan on pursuing a full vehicle wrap.
It seems best left to pros but my car is in primer already and before i pay $3k to paint it, a $300 plus labor vinyl attempt is in order.
The 3m product seems the most recommended, so the education begins.
I have a few discreet vinyl cf interior pieces and I like them.
Old Oct 31, 2011 | 11:15 PM
DarkDrakeX's Avatar
RX-7 NUT
Ive herd the vynal wrap on the exterior is hard to keep clean looking (it shows dust and dirt alot). ive thought about buying a bit and doing osme of my interior pieces just to see whats up.
Old Nov 7, 2011 | 05:41 PM
JAX04's Avatar
Ive used some on some interior bits myself, and found that probably the most important part of using this stuff is the preparation. i scuffed my surfaces, then cleaned them, then used a 1200grit paper and made them smooth again. cleaned everything down with brake cleaner and or acetone, and it came out phenomenal.
Now for the exterior, ive seen two car with it, and they were freshly wrapped, and they looked pretty good. However, id think my main concern would aligning the peices so it looks smooth and not broken up.
Like i said, if anyone is gonna try this stuff, prep the hell out of the surface. In for pics if you go for it
Old Nov 7, 2011 | 06:12 PM
PierRX's Avatar
I vinyl wrapped my hood and headlight cover. Paint was oxidizing and headlight cover was new and needed paint. Cost me 80 bucks total.
Old Nov 7, 2011 | 06:19 PM
PierRX's Avatar
If you look closely, you'll see some bubbles on the hood. But they went away as the wrap heated up.
Old Nov 7, 2011 | 08:18 PM
silverfdturbo6port's Avatar
500+hp club
My work is the only 3m dealer for the northwest. We do the carbon vynal all the time. Heat helps alot. Using the heat of the sun is the best. Always use a primer like 3m primer 094 or windshield glue primer for the metal. Use the primer on all edges to keep from coming up.
For more info and pricing on the REAL 3M carbon vynal give my work a call 509-927-0581
Old Nov 7, 2011 | 09:50 PM
500+hp club
wow i need to learn to spell vinyl correctly lol
Old Nov 8, 2011 | 07:10 PM
DarkDrakeX's Avatar
RX-7 NUT
Lol i did it too with the spelling. And that looks really good. Hah i kinda wonder how it would look on a FB. I kind of want to try it now. Im still curious as to how easy it is to clean,, if it gets rocks ripping it easy,, if it sunfades easy, as wel as if it stays clean looking.
Old Feb 1, 2012 | 11:07 AM
felix_is_alive's Avatar
hahahahaha, when i read it i thought it was some female hygene product
Old Feb 1, 2012 | 07:07 PM
JonWhiting21's Avatar
yes pistons...
I have to find pictures, but I have a few friend that have covered their canards, and wing bases...it comes out pretty well even on tight bends.
Old Feb 2, 2012 | 11:38 PM
lonewolfrx's Avatar
how much is needed to cover a whole hood and cost of it? my fc is fading and would just like to wrap it.
Old Feb 23, 2012 | 10:56 PM
rotary_rob's Avatar
you are looking around $75-90 to cover a hood
Old Feb 28, 2012 | 11:58 PM
muibubbles's Avatar
Bubblicious DEF.
this may help some of you attempting this...
http://www.youtube.com/watch?v=yOGwl...eature=related
Old Feb 29, 2012 | 02:57 PM
tru_az1an's Avatar
mr.niceguy
^cool vid!
Old Mar 12, 2012 | 11:12 PM
clos84's Avatar
any wrapped fc pics?
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
