fit 225/50's in the front?
Old Jul 17, 2002 | 11:09 AM
Crusader_9x's Avatar
how may people here can fit 225'50's inthe front without rubbing? i got a 89 tII and i know that the rim wil handle the tire fine. i just dont know if it will ru the spring in front or not.
Old Jul 17, 2002 | 11:11 AM
T2 Tsunami's Avatar
Stud Service
16-17"?
Old Jul 17, 2002 | 11:25 AM
incendui's Avatar
if I remember right, 225/50 on a 16in rim is the same diameter as the stock tire and rim. Thats what I have on the front of mine now, and theres plenty of clearance.
Old Jul 17, 2002 | 11:33 AM
Grimlock's Avatar
i have 225/50/16 up front with stock springs and shocks. i dont have any problems. i dont like that size id prefer maybe 225/45, that should look better.
than again i have some fugly goodyear hp's, those ******* are ugleeeee!
Josepi's Avatar
Despise Enmity
It is, and what I run.
Old Jul 17, 2002 | 11:45 AM
yah they are the stock 16 x 7. k cuz i am needing tires pretty baddly and i ddint know if that size would fit. yah i was thihnkin about the 225/45 also. but the same tire ina 45 series is almost ten bucks more thatn a 50/s series.
Old Jul 17, 2002 | 11:51 AM
gnx7's Avatar
Crusader 9X- If you can spend it... get the Bridgestone S-03's. I have them and they are the best tire that I have put on the car as far as a street tire goes. 225/50/16's up front and 245/45/16's out back on stock '89 T2 rims.
GNX7
Old Jul 17, 2002 | 12:12 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
It depends on the tire. Some tires have a wider section width than others. I run 225/60/15 Yokohama AVS dB on the front. No rubbing, but maybe 1/8" clearance to the spring perches.
Brad
Old Jul 17, 2002 | 01:38 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm running 225/50 t1-s on stock rims with k2rd coilovers. very close.
Old Jul 17, 2002 | 01:52 PM
T2 Tsunami's Avatar
Stud Service
I have 235/45/17's yoko all around, the front does rub when I turn completely to either side, but it's not bad..just touches.
Old Jul 17, 2002 | 02:09 PM
fastrotaries's Avatar
W. TX chirpin Monkey
fits good the tire does.
Old Jul 17, 2002 | 02:44 PM
Turbonut's Avatar
It's like Brad stated. Depends on the brand. Yoko's did fit, but Michelin's didn't. Sidewall rubbed.
Old Jul 17, 2002 | 02:45 PM
No7Yet's Avatar
I run 225/50R16s all around - fits and looks great. I'd go with Falken Azenis; they've got a great price for an even better tire
Don't go 225/45R16s, as it'll make your speedo read high for little to no gain.
Brandon
astrum
24
Nov 15, 2017 08:44 AM
fidelity101
13
Aug 31, 2015 07:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
