lights wont go off
Old Jul 17, 2002 | 12:51 AM
lights wont go off
my side bulbs (or parking lights)wont go off?they just glitched and stayed on.is the switch by the steering wheel broke?i checked fuses non are burnt.i hafta disconnect the battery to turn them off.pleez help
Old Jul 17, 2002 | 12:59 AM
kundo's Avatar
I would say you're switch is probably broken. You should take it apart and see is broken, or can be fixed.
Old Jul 17, 2002 | 01:04 AM
how do i take it apart though?
Old Jul 17, 2002 | 01:09 AM
kundo's Avatar
Don't know really. Does the switch still click 3 times still, or did it get harder to turn it. I don't know if it will break if you try to pull on the ****.
Old Jul 17, 2002 | 01:20 AM
it still clicks 3 times
Old Jul 17, 2002 | 03:13 AM
jspecracer7's Avatar
1JZ powered
could be relays?...
Old Jul 17, 2002 | 12:42 PM
GsrSol's Avatar
Z06 powered FD
If a fuse was bad it would break the circut causing them not to come on at all. For the time being, just pull the fuse instaed of unhooking to battery.
Old Jul 17, 2002 | 03:15 PM
which fuse is it to take out the parking lights?believe im blind.stuff that is right under my nose i can never see
thanx
p.s. oh yeah which relay could it be?
Old Jul 17, 2002 | 03:17 PM
futurerexowner's Avatar
I would check the relays if I were in that situation. If the switch feels fine...although it could still be a bad lead inside the switch...
Old Jul 17, 2002 | 03:44 PM
i just asked which relay was it?
Old Jul 18, 2002 | 10:16 AM
bump
Old Jul 18, 2002 | 10:52 AM
bump
Old Jul 18, 2002 | 11:24 AM
GsrSol's Avatar
Z06 powered FD
Look at the cover for the fuse box under the dash, if you don't have a cover just start pulling fuses until they go off
Old Jul 18, 2002 | 02:51 PM
i found it it wasnt under the dash it was inder the hood by the name of b2 i believe.
Old Jul 18, 2002 | 03:00 PM
nocab72's Avatar
03 Cobra Killer
unhook your battery, they will go off.
Seriously, your relay could go bad and stop functioning in the the "ON" position causing your lights to not shut off.
K
Old Jul 18, 2002 | 03:20 PM
thanx nocab.but hmm the relay has no broken metal piece in the middle.what do u think it would be now?could it be somehwere else in the relay?
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
