Ceramic Coated Headers
Old Jul 16, 2002 | 11:23 PM
jayroc's Avatar
Anyone done this or know of its benefits? I know coating the exhaust manafold of a piston engine is somewhat beneficial, but what about rotaries?
Old Jul 17, 2002 | 09:20 AM
Spieder's Avatar
Ceramics are insulaters. RX-7's have a hollow double walled exhaust manifold to help dissipate heat and keep them from being damaged. Coating the outer wall with a ceramic would only make the manifold hotter on the inside. I don't see why that would be good.
Old Jul 17, 2002 | 10:01 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
yea, coating the inside would be good though. it can be done.
Old Jul 17, 2002 | 11:12 AM
Hans's Avatar
it keeps thermal energy up, keeps exhaust velocity up, good thing, but yes it does keep exhaust hotter than a sumenbitch
or thats what i was lead to believe
oh and hes talking about coating headers
Old Jul 17, 2002 | 11:51 AM
diabolical1's Avatar
i thought i read somewhere that having the exhaust keep it's heat inside is supposed to be a good thing. i can't remember if there was supposed to be a power gain related to it, but i do remember reading that it was good for overall combustion. i mean, isn't that the premise behind header and turbo wraps?
anybody know the truth on this????
Old Jul 17, 2002 | 12:56 PM
jeremy's Avatar
male stripper
ok, here is how it goes. exhaust coatiings/wraps keep in heat (energy) which keeps the exhaust gases flowing quicker. in turn this will scavenge more exhaust gas from the chamber giving you a cleaner mixture for the next combustion process. it also helps to keep heat out of the engine bay allowing the carb to run cooler (cooler air=bigger bang) and generally letting angine bay components last longer.
downsides. if it is a blanket or wrap then the heat is being contained on the outside wall of the metal. this will cause the metal to fatigue much quicker, especially with a rotary, and the header will crack and fail sooner. this is worse of course with a wrap or outside coating since they are more effecient then a blanket.
however, if you get the header coated inside and out, it is a double wall so it is more effecient and most of the heat is stopped on the inside so the header will last longer then it would bare. so this is a plus plus situation. improved performance and heat protection for the header and engine bay.
Old Jul 18, 2002 | 07:47 AM
jayroc's Avatar
headers and stuff
That was my understanding, too. Performance gains are small, but it helps keep the underhood temps down and extends the life of your headers/exhaust manafold. jet-hot has a service that can do it, really good, from what I understand. Not sure how much, but when I (eventually) get an exhaust setup, I'll probably get my headers coated. thx
Old Jul 18, 2002 | 08:14 AM
Directfreak's Avatar
I am a Jeeper Now.
Re: headers and stuff
Is there any other place besides JET-HOT that does this?
I know it's a great product, hands down.
Unfortunately, all I have heard from them is that they take too long (weeks), charge too much (several hundred), and sometimes crack your manifolds with crappy shipping, - which we (the consumer) pays for both ways (to and from).
Old Jul 18, 2002 | 03:40 PM
Rotary-MG's Avatar
the name is Stan
Anyone know of a place that does Ceramic Coating?
Inside as well?
I made up a custom header for my project car, and after all that work, i'd like to make them last longer. I also have to control the heat. So keeping them cool isn't an option.
Old Jul 18, 2002 | 09:08 PM
jayroc's Avatar
custom headers
Well, jet-hot does offer a warranty/guarantee, so if they cracked during shipping, I'm sure they'd reimburse you. I don't know how much it costs, though.
RacingBeat sells header kits you can weld together yourself for around $80. Stainless 309 and mandrel bent. So, if you can weld, that's a good deal.
BTW, ordering direct from RB is a bit cheaper than mazdatrix.
http://www.jet-hot.com/faq.html
Andrew7dg
Aug 6, 2017 01:41 PM
