Clutch
Old Sep 6, 2011 | 10:06 PM
jdr821's Avatar
Clutch
Hi guys. What clutch are you guys using in yours 20 b? I was thinking of buying the max extreme clutch from extreme clutch.
Old Sep 7, 2011 | 05:24 AM
Banzai-Racing's Avatar
Rotary Specialists
It depends on how much power you plan to make. I use an Exedy twin disc on my car.
Old Sep 7, 2011 | 06:01 AM
jdr821's Avatar
im looking to be in the 550-600 whp. I have the fidanza flywheel on now.
Old Sep 7, 2011 | 08:43 AM
TRWeiss1's Avatar
LSx 7.0L
The exedy twin disc should handle that with ease. That's what I'm currently running at a bit over 500RWHP, and it takes everything I can throw at it. I plan on going a bit higher (probably to the 550RWHP range) within the next couple months, although it might get pushed out to next year.
Old Sep 7, 2011 | 11:38 AM
RZMotorsports's Avatar
1000hp Quest
I have the perfect clutch for yo, i have a used ORC 3 disk clutch kit, it comes with lighten flywheel, 3 clutches, pressure plate, and adapter kit. I only used it for around 50 miles went with a trans conversion because of power levels over 1000hp. the clutch kit is good for 800hp no problem so it will last you forever if you are only going to run it at 550-600 its an amazing clutch kit it comes with everything my lost is your gain!. let me know if you are interested and i can send you pics.
Old Sep 7, 2011 | 06:05 PM
Rotary Specialists
^ Pretty sure your clutch will not do him any good. The fact that he is looking at the Max Extreme would mean that he has an FC, not an FD.
JDR- with your HP goal I would go with an Exedy multi disc. It will come with with a balanced flywheel, so you can sell off your Fidanza.
Old Sep 12, 2011 | 12:42 AM
ReZ311's Avatar
KM48 Burnout
Has any tried the SPEC Mini Twin disk?
Old Sep 16, 2011 | 08:28 AM
1000hp Quest
clutch pics
here are some pics of the clutch for anybody that is interested.
Old Sep 19, 2011 | 04:45 PM
hIGGI's Avatar
OS Giken twinplate TS2A.....just broke stock S5 TII transmission (after 5 drift events)
Old Sep 23, 2011 | 10:43 AM
stevensimon's Avatar
what do you guys think of this.
sintered iron disk
stock t2 trans
drift events, clutch kicking, abuse
http://www.jdmultimate.com/clutch_ma...ZDA&Model=RX-7
Old Mar 25, 2016 | 04:20 AM
Bottled Morphine's Avatar
Still have this?
Old Apr 3, 2016 | 10:13 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
an old thread but still relevant...
while i run a 2 rotor i do have a solution for anyone running a Tremec trans.
Mcloed double disc RST. i run it behind my 2 rotor and my T56. it is spectacular as to feel. makes driving fun again which it was not w my Quartermaster DD.
supposedly it holds 800 ft pounds.
Beyond Redline.com has a couple in stock along w Tremec Magnum-non-Magnum alu adapter.
one of the keys is the custom Mcloed flywheel.
nice setup.
Howard
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
