Without a boost controller, how can i turn up the juice
Old Jul 16, 2002 | 03:45 PM
I dont have a boost controller right now, and im running very low boost. It was set low when the motor was put in, and i want to bump it up alittle.
How can i manually do this from under the hood?
making sure its safe of course.
Old Jul 16, 2002 | 06:34 PM
Aaron Cake's Avatar
Engine, Not Motor
You'll either need to install a boost controller (even a manual one made out of an aquarium air valve) or put some kind of restriction in the air hose to the wastegate.
Old Jul 16, 2002 | 06:51 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Without a boost controller, how can i turn up the juice
How much is low? With your mods you should be seeing over 8psi, anything less than that means something’s wrong.
There’s no underhood boost adjustment, it’s controlled by the tension of the wastegate spring. What to you mean by “set low”? Apart from boost creep due to a restrictive wastegate, a boost controller is the only way to raise boost.
Old Jul 16, 2002 | 10:21 PM
i recently had the motor checked by t&r racing in queens, and another place on long island that speciallizes in rotary. they both said that i have a strong motor, it runs smooth, compression is fine, etc..
but i have trouble getting the boost up past 5 or so.
i dont know if my cats clogged or something, maybe my wastegate is screwed up, i dont know. Btw, my timing is set alittle retarded, but i dont think that would keep the boost so low.
any ideas?
Old Jul 16, 2002 | 10:26 PM
...i have trouble getting the boost up past 5 or so.
i dont know if my cats clogged or something...
If you have stock 15yo cats this is almost definitely the problem.
Old Jul 16, 2002 | 11:58 PM
Scott 89t2's Avatar
SOLD THE RX-7!
with a ported WG and stock cats I doubt it would go over 5. that just means the WG is doing it's jop. just get a manual boost controler. I bought one off ebay for $25.
Old Jul 17, 2002 | 01:20 AM
No, the cats should be taken care of first. A MBC would just force the turbo to work even harder to overcome the clogged cats.
Fix, then modify; don't modify to fix.
Old Jul 18, 2002 | 05:29 AM
yeah my cat is probably clogged, but what else would it possibly be? cause its not my motor per say.
m
Old Jul 18, 2002 | 05:35 AM
jspecracer7's Avatar
1JZ powered
$20 says it's your cats. If you've never had them replaced, then ...
Old Jul 18, 2002 | 06:25 AM
87GTR's Avatar
want more boost get a fish tank air valve and splice itinto you waste gate line
Old Jul 19, 2002 | 03:56 AM
does anyone have a pic of the fish tank air valve installed?
hows the turboX manual boost control?
Old Jul 23, 2002 | 05:50 AM
Old Jul 23, 2002 | 06:13 AM
fastrotaries's Avatar
W. TX chirpin Monkey
the turboXS is a great buy for the money. I would replace your cats, and you WILL see the boost go up. At least you got rid of the pre-cat and put in a DP
Old Jul 23, 2002 | 04:32 PM
i have a 3 inch downpipe. the main must be clogged.
is there a good chance ill thin out once i clear the cat at high rpm?
mike
Old Jul 23, 2002 | 06:12 PM
VetteKiller's Avatar
fix the cats! you can overwork/overheat the turbo by just cranking up the boost and then you can destroy all sorts of stuff. Like NZ said, fix it and buy a $40 MBC and crank your boost up to 9 or so
Old Jul 24, 2002 | 06:53 AM
super! =) will do
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
