Replacing spark plugs
Old Jul 16, 2002 | 10:11 AM
ddr10's Avatar
Can anyone recommend the plugs to get?
Old Jul 16, 2002 | 10:12 AM
ttpowerd's Avatar
HARRRRRRRRR
What mods do you have?
Stock is 7's leading and 9's trailing
Slightly modded is 9's all around
Heavy modded is 10's or 10.5's
Old Jul 16, 2002 | 10:36 AM
ddr10's Avatar
M2 Med IC, M2 intake, N-tech DP, Magnecor 8mm wires, AST Kit, Catback - midpipe soon, Power FC.
Old Jul 16, 2002 | 11:18 AM
ttpowerd's Avatar
HARRRRRRRRR
9's all around...NGK's
I think they are about 8-9 bucks a piece
Old Jul 16, 2002 | 11:23 AM
Mahjik's Avatar
Mr. Links
Plus some Anti-Sieze..
Old Jul 19, 2002 | 12:01 AM
daem0n's Avatar
RE-Amemiya in the blood
If you don't have a lot of mods what would 9's all around do? Could it cause damage or are you just wasting money? Like is it a better to be safe than sorry situation?...lol
Old Jul 19, 2002 | 12:04 AM
trigeek37's Avatar
I paid less then $20 at the local Checkers for 4 9s this evening
Old Jul 25, 2002 | 05:29 PM
daem0n's Avatar
Does anyone know about my question?
Old Jul 25, 2002 | 05:36 PM
R Xplicit's Avatar
i buy mine at advance auto parts. 7's and 9's and i am quite heavily modded. however, this is the plug set up that i was told to use....should i go with 9's all the way around?
btw, they were 6.69 each....
louis
Old Jul 26, 2002 | 06:26 PM
daem0n's Avatar
what happens if you use 9's when you should be using 7's?...anybody?
Old Jul 26, 2002 | 09:17 PM
jspecracer7's Avatar
1JZ powered
9's are the cooler plug. You run more mods, you want to have a bit of safety as far as pre-ignition...9's.
Old Jul 27, 2002 | 02:07 AM
daem0n's Avatar
Is there any way to test what plug you should have according to your mods? Everyone just seems to guess or get someone else to tell them. I hear 7's and 9's, just 9's, etc, etc...
Old Jul 27, 2002 | 02:10 AM
1JZ powered
Just put 9's in. With or without mods. **** it.
Old Jul 27, 2002 | 02:15 AM
lane_change's Avatar
It has begun
Look at my sig.
Should I run all 9s? I have 7's and 9's right now. Jason form RX7Store recomended them to me. What does everyone else think? I am replacing them next week as well as my wires with either Magnecore 8mm's, Jacobs Wires, or stock NGK's. Any recomendations there as well?
Old Jul 27, 2002 | 02:22 AM
DK's Avatar
DK
40k worth of fail
Exactly. You won't hurt anything running all 9s, but you could hurt something running 7s. Everyone who asked "Look at my mods blah blah blah should I use them I was told this and that," there is your answer.
NGK part number for 9 platinum is BUR9EQP, by the way. They're cheap at Advance, and wherever you go they'll be the "trailing" plugs if they ask.
Old Jul 27, 2002 | 03:52 AM
1JZ powered
Originally posted by lane_change
Look at my sig.
Yep. Run 9's. Part number BUR9EQ. Trailing plug
BUR9EQP is the platinum trailing plug.
Old Jul 27, 2002 | 10:14 AM
A-Spec's Avatar
Those of you that got them cheap, check to see if you got the platinum one. BUR9EQP, if they are indeed platinums, you got a good deal.
There's also the NGK racing B10EGV single electrode spark plugs....I won't say which is better, they both get their jobs done.
David
Old Jul 27, 2002 | 10:36 AM
1JZ powered
I just went over to the second gen section. Seems like they asking the same questions...
Old Jul 27, 2002 | 01:44 PM
1JZ powered
Originally posted by Dont_Be_A_Rikki
without have'n A/C and P/S makes changing plugs quick and easy.
J, you know what I am syaing
HELL YEAH!!!! I can see my spark plugs. I remember how hard it was before pulling all that stuff out. Now I can reach down and touch my motor mounts
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 19, 2015 06:27 PM
Joe428
16
Aug 19, 2015 06:24 PM
