Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
What do I use to cut Plexiglass
Old Aug 23, 2011 | 11:42 PM
misterstyx69's Avatar
Retired Moderator, RIP
I got a RE Bumper that didn't come with the Plexiglass light covers,So I bought a piece of 1/16?.1/8th? plexiglass..Real thin stuff you can bend to conform to the bumper without having to Heat.I just don't wanna Screw it up!
Anyways,I am looking for suggestions on how to cut this Sheet of Plexi.
If I cut it right I can get 4 pairs of "lenses".(10" x 10" each lens..and sheet is 2x4 Feet)
Thanks guys..Cheers Dave/STYX.
Old Aug 24, 2011 | 12:22 AM
CJarrett's Avatar
FC Racer
Skil saw, with a blade with as many teeth per inch you can find!
I'd use 1/8th, the 1/16th might look warped as its so thin, the rivets or glue holding it down might distort it. Even 1/4 will conform enough.
Old Aug 24, 2011 | 04:51 PM
Level Zero Motorsports's Avatar
Registered User
Skill Saw, Band saw, Miter Saw or even a jig saw (if you are brave). Tape the area you want to cut in order to not scratch the plastic, or put tape on you saw.
If it is plexiglass (polycarbonate) and no acrylic, then you shouldn't have too many problem.
Old Aug 27, 2011 | 10:00 AM
Aaron Cake's Avatar
Engine, Not Motor
I've always used a jigsaw with a "particle and chip board" blade. It has large teeth, with small teeth in between. Tape the area very well and keep the speed just below the point where it melts.
Old Aug 27, 2011 | 01:08 PM
Prometheus's Avatar
Still got it.
Go with PolyCarbonate, its much more durable than plexiglass
tape
when it comes time to bend/ mount it you are goint to have to soften it up with either a hot sand box or boiling water.
definately go with 1/8" its just teh right thickness
1/4 " will be too thick and not match the bumper
1/16" will expand, warp, buckle from sunlight
Old Aug 27, 2011 | 11:54 PM
I was able to do it with a Skilsaw,and a dremel with a disc for the Curvy parts.
posting a pic.
It isn't the best pic as it was getting dark,and I hadn't cleaned up the Car.(washed it).
yes the hood is opened!
Old Oct 9, 2011 | 09:12 PM
emperorbob5's Avatar
That looks sweet. How much bend could you get out of it? I have a GTC bumper for my FD and I kinda want to do the turn lamp covers.
Aramir
Oct 18, 2015 02:39 AM
