Canadian Forum Canadian users, post event and club info here.
finally tuned on the 35r setup!
Old Aug 21, 2011 | 10:06 AM
Andrew777's Avatar
Rotating
It took a few trips to the dyno and some troubleshooting with an ignition problem but i finally finished up last night with some decent numbers
List of mods
power fc
"smog" port motor
2mm 2 piece mazda seals
spec stage 3 clutch
550/1300cc injectors
Fjo injector resistor pack
aeromotive fpr
Aem watermeth kit
Supra fuel pump
re-wired fuel pump
(4) ngk R heat rating 9 plugs
Hks twin power
rx7 store gt35r kit t4 1.06 hot side
tial mvr (44mm) gate
3" straight through exhaust
greddy 3row fmic
94 octane petrocan premixed 200:1 w/ synthetic 2 stroke
363 hp @ 13 psi with afr's between 10.8 to 10.6 on a dynapack dyno.
Old Aug 21, 2011 | 04:16 PM
thewird's Avatar
Congrats, why so rich?
thewird
Old Aug 21, 2011 | 05:15 PM
Andrew777's Avatar
Rotating
safety more than anything, lean it out next spring with some bigger secondaries and a 3bar map sensor.
Old Aug 21, 2011 | 07:07 PM
JDK's Avatar
JDK
Let the fun begin.....
Old Aug 21, 2011 | 09:15 PM
Double_J's Avatar
Pretty good #'s. I thought you bought the kg fuel system from me last year. Anyway congrats!
Old Aug 22, 2011 | 10:14 AM
FC3Sdrift's Avatar
Displacement Replacement
pretty close to mine, i made 361whp and 309ft-lbs with my hybrid turbo, stock ports and 2.5" dp
Old Aug 22, 2011 | 04:05 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
add boost
remove fuel
go even faster!
Old Aug 22, 2011 | 07:12 PM
Andrew777's Avatar
Rotating
Originally Posted by Terrh
add boost
remove fuel
go even faster!
Have some fun this fall, tear it down in the winter, bigger ports, 3mm seals and yes, more boost and tuning.
Old Aug 22, 2011 | 10:00 PM
R.P.M.'s Avatar
Likes to swear....alot
I dont want to start any sort of debate, but why 3mm?
Old Aug 22, 2011 | 10:17 PM
FC3Sdrift's Avatar
RA superseals!
Old Aug 22, 2011 | 10:34 PM
thewird's Avatar
And it begins
thewird
Old Aug 23, 2011 | 06:33 AM
R.P.M.'s Avatar
Hahaha no no, I'm just curious why someone would choose 3mm seals?
Old Aug 23, 2011 | 08:51 AM
thewird's Avatar
You know I had typed out out a post in response to his 3mm but then decided to close the tab instead cause it always ends up in a back and forth :P
I'm just going to say 3mm isn't needed but an upgrade over stock 2mm would be preferred. 2mm idles better also.
thewird
Old Aug 23, 2011 | 06:19 PM
Double_J's Avatar
A safe bet is the op feels they are better for his intended use based on his on research and understanding.
Old Aug 23, 2011 | 06:49 PM
IAN's Avatar
IAN
Rotary Reborn!
I have 3mm. Its bigger then 2mm so its better
And you can choose 3mms if your rotors are not in spec for 2mm's
Old Aug 23, 2011 | 10:18 PM
R.P.M.'s Avatar
Thats the only reason I can see someone choosing 3mm over 2mm, if thier rotors are just worn out.
Old Aug 24, 2011 | 01:50 PM
JDK's Avatar
JDK
I use 3mm oem seals....have done for a few years now, whats the problem here?
Old Aug 24, 2011 | 03:02 PM
Lynch's Avatar
Lynch
Who tuned your car? I'm looking for a local tuner.
Old Aug 25, 2011 | 02:09 PM
JDK's Avatar
JDK
Who are you asking? If your referring to me, Marco tunes my car and has done so for 3 years now
Old Aug 25, 2011 | 07:56 PM
Andrew777's Avatar
Rotating
if your asking me, I did, if your looking for a tune, see marco.
Skeese
65
Mar 28, 2017 03:30 PM
Jun 26, 2016 10:21 AM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
s2kguy17
Rotary Drag Racing
Sep 15, 2015 03:05 PM
Wolf_
Aug 11, 2015 04:23 PM
