Cash value of a streetport motor with <2k?
Old Jul 16, 2002 | 12:08 AM
nimrodTT's Avatar
all aboard!
I'm thinking of selling my current motor to help pay for a bigger streetport. This one is cut at 58 degrees (it may have been something else, I have it recorded somewhere), has the water jacket modification, the 17.5mm oil pump, mazdacomp oil jets, lightest front counterweight, 80 or earlier rotor housings, lightest 12A rotors and the 23# flywheel. I built the motor myself, it runs perfect and has lots more power than my stockport had, but I want to go faster. About 1800 miles on the clock.
How much is it worth on the open market? I can ship and I'd be more than willing to install it in someones car if they paid me.
Old Jul 16, 2002 | 08:33 PM
nimrodTT's Avatar
all aboard!
No one wants a streetport?
Old Jul 16, 2002 | 10:16 PM
mar3's Avatar
Administrator
Just like any modded engine, no one wants to pay you what you think it's worth...I can tell you for sure that no hi-po engine ever resells for what it cost to put it together...you can't even get the total price of the parts in the engine on a resell situation. I'm thinking that most of the members in this 1stgen corner are all tossing the number $500 in their head. Would you accept that amount? That's why no one will reply...
Old Jul 17, 2002 | 02:13 AM
nimrodTT's Avatar
all aboard!
I've seen stockports with tens of thousands of miles go for more than that. I guess I'll just keep it then and save up for the big one, maybe I'll go bridge.
Old Jul 17, 2002 | 07:59 AM
V8kilr's Avatar
you could get $800.00 out of it,
i dont think any more then $1,000.00 though
Old Jul 17, 2002 | 09:20 AM
WackyRotary's Avatar
standard combustion
That doesn't make sense? If you put it together with the lightest 12a rotors from a 83-85 and used a earlier front counterweight from a pre 83, the engine would be out of balance. It would run, but would have some vibration when you rev it up near or above 7000rpm.
qoute from Mazdatrix:
Important note on counterweights: The front and rear (or flywheel) counterweights PLUS the rotors make a balanced assembly. The years / rotors we list in the following charts are for PRODUCTION years of the rotors / counterweights! A lot of mixing can be done when building engines, providing the rotors and counterweights match. By this we mean 89-92 non-turbo rotors (lighter weight, higher compression) can be used in an 84-85 13B engine as long as the matching front and rear counterweights are used also, for instance.
I wouldn't run that engine without the right front counterweight on it if I were you. Did i miss something?
Old Jul 17, 2002 | 12:07 PM
V8kilr's Avatar
uh oh
Old Jul 17, 2002 | 01:19 PM
mar3's Avatar
Administrator
NOW the number going through everyone's head is about $300 and they're hoping you didn't run it too much so they can correct the mistake on the cheap...
Old Jul 17, 2002 | 01:20 PM
nimrodTT's Avatar
all aboard!
Don't worry, I did my research. No vibrations up at 8500 so I'm sure I got the right advice on the counterweights (from Mazdatrix).
Old Jul 17, 2002 | 01:22 PM
nimrodTT's Avatar
all aboard!
Everyone sure is quick to fall in line with the crowd, aren't they?
Old Jul 17, 2002 | 01:38 PM
mar3's Avatar
Administrator
The worst pack of sheep I've seen in a while...just try attacking any topic that falls under rotary religious dogma and watch the ants pour out of the mound....
Old Jul 17, 2002 | 09:49 PM
V8kilr's Avatar
try $150.00
im selling mine for $300.00 and its factory balanced
Old Jul 17, 2002 | 09:54 PM
Defprun's Avatar
Punk Ass Bitch
You still gonna sell me that hood V8?!
Old Jul 18, 2002 | 01:19 AM
nimrodTT's Avatar
all aboard!
Originally posted by V8kilr
try $150.00
Every rotating assembly was balanced by the factory, so that doesn't really say too much. Now if it was a balanced factory race motor...
Old Jul 18, 2002 | 11:20 AM
mar3's Avatar
Administrator
Then he could ask for $400!!
Old Jul 18, 2002 | 01:42 PM
crankit's Avatar
Value is usually somewheres in between what you want and what they want to pay. Its called making a deal.
1987 T2
11
Apr 1, 2017 11:59 PM
doritoloco
Sep 5, 2015 12:41 PM
