GSL-SE Exhaust Question
Old Aug 18, 2011 | 05:08 AM
grotto107's Avatar
Does anyone know the difference between the intermediate exhaust pipe for an 84 verses an 85? They have different part numbers. Thanks.
Old Aug 18, 2011 | 07:57 AM
rotordogg's Avatar
Customizer
If you are referring to the pipe that goes from the rear cat to the muffler, it is the exact same part. Bosal part number 834-337. Who is giving you two different part numbers?
Old Aug 18, 2011 | 09:18 AM
campaiar's Avatar
GSL-SE'er
You can even use the 12a part if you like. It has an extra port out the side that you'll need to plug, but the bends, flanges and hangers are the same.
Old Aug 18, 2011 | 09:37 AM
RX-7 Chris's Avatar
it does show two parts numbers in the parts catalog.
'84 SE: N304-40-200A
'85 SE: N304-40-200B
There are also different parts numbers for 12A's and auto 12A's.
No idea if there is actually a difference. I need to replace this pipe on mine.
Old Aug 18, 2011 | 10:21 AM
grotto107's Avatar
The Mazda factory parts manual (page 1-L10)shows a different # for pipes made up to Feb 1984 and pipes made thereafter.
Old Aug 18, 2011 | 10:35 AM
RX-7 Chris's Avatar
Do you know if the Bosal part comes with the tabs to mount the heat shield?
Old Aug 18, 2011 | 11:23 AM
j9fd3s's Avatar
Community Builder
both are NLA from Mazda. i'd bet the change was something dumb like the supplier, and IF it was available you would have gotten the N304-40-200B.
i guessed at the part number, but the N249-40-200B is NLA also.
Old Aug 18, 2011 | 12:05 PM
RX-7 Chris's Avatar
I was planning to have a new one made at a local exhaust shop.
Old Aug 18, 2011 | 12:13 PM
campaiar's Avatar
GSL-SE'er
I got a brand new one from NAPA two months ago. Less than $70.00.
Old Aug 18, 2011 | 05:00 PM
grotto107's Avatar
Will it fit an 85 GSL-SE?
Old Aug 19, 2011 | 08:59 AM
RX-7 Chris's Avatar
$70 isn't bad, probably couldn't get one custom made for that.
Skeese
65
Mar 28, 2017 03:30 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
12abridgeport
Aug 17, 2015 06:28 PM
