Ignition setup opinion
Old Jul 25, 2011 | 12:51 PM
RotoricanNY's Avatar
A.K.A. R-Cien
Question Ignition setup opinion
Thinking about upgrading my ignition system, I'm not too wise when it comes to non EFI stuff, here's what I got.
6 port 13B outta an S4
dellorto 48dhla side draft
RB intake & header
full RB exhaust.
I've heard many many things about MSD Blaster 2 Coil, which I know is a direct replacement to my stock coils. I've also heard of 6AL ignition control box, how could I benefit from that? is it even necessary to run on a DD? Also is there a different route to upgrade my ignition.
All in all I just want something that's going to give me more power and reliability. Sorry for all the noob questions.
Old Jul 25, 2011 | 01:02 PM
81WideMariah's Avatar
Slave to the Rotor!
don't expect massive power gains from any ignition upgrade on an NA....
But one of the best/most popular routes is to use a MSD 6A and a 2nd Gen Leading coil, which will give you wasted spark and direct fire ignition.
Search for 2GCDFIS with MSD.
Old Jul 25, 2011 | 01:10 PM
t_g_farrell's Avatar
Waffles - hmmm good
Even better, check my sig for a link to the TFIDFIS. Swaps out the ignitors for GM 4
prong HEIs ( or 7 prong) and FORD TFI coils. Its a great ignition and better than
using the 2G coild which I had previously.
Old Jul 25, 2011 | 03:04 PM
A.K.A. R-Cien
I've heard of 2GCDFIS,but not of TFIDFIS, will look it up, thanks.
Old Jul 25, 2011 | 04:34 PM
patmac6075's Avatar
Once a Marine.....
I've been running the 2GCDFIS for a little over a year and have been very satisfied. If I burn out an igniter I'll switch over to TFIDFIS....from what I've read (TG's posts) it sounds pretty straight forward.....but it's voodoo science to me.
Old Jul 25, 2011 | 04:48 PM
Slave to the Rotor!
Plain 2GCDFIS is too hard on a stock J109 Ignitor.... but adding an MSD 6A makes for a pretty potent ignition set up.
Old Jul 25, 2011 | 08:34 PM
Twilightoptics's Avatar
Boosted Soon
I thought the ignitor was just a trigger at that point?
Old Jul 25, 2011 | 09:40 PM
A.K.A. R-Cien
I'm so lost :-(
Old Jul 26, 2011 | 07:21 AM
Waffles - hmmm good
The problem is the 2G coil stresses the stock ignitors. The HEI ignitors can pass
more current 4-6 versus 3-4 and can drive hotter coils with no issues. Also all these
stock ignitors are getting 30+ years old now and failing at increasing rates due
to age alone.
Using proven, off the shelf parts just makes sense. The HEIs have been
proven time and again to work well and the TFI coils are known for being tough
and mountable in any position with no problems. Put them together and its magic.
Its a much cheaper solution than going up a notch to an ignition box or standalone.
If your running a non-stock engine to higher than stock rev limits, then those are
required but for a stock rev range the HEI/TFI combo works great.
Old Jul 26, 2011 | 08:43 AM
Slave to the Rotor!
When running an MSD there's no need for and ignitor.... it will actually trigger directly off the magnetic pick up in the distributor. Great way to replace a failed ignitor. You can usually find used 6A boxes on Craigslist and such for around $50. An MSD also allows the use of the FC coil without degradation of spark voltage at higher RPM since the MSD box charges much more rapidly than any coil can. After charging, the MSD fires approximately a 250v charge into the coil which amplifies that to about 25,000v. That's why MSD boxes work so well and are so popular.
Old Jul 26, 2011 | 09:48 AM
Verneuil's Avatar
Think ur math is a lill off. 12V is converted to around 15K to 20K on the stock coils. Maybe more or slightly less. A 250V jolt would produce somehwere around probly 40K or 50K on the stock coil. But that is done rapidly under 3000 rpm i think. Then it uses a single spark from there. the TFIDFIS is the way to go. I had a MSD 6AL on my first Rx7 83 also. I saw no improvment with it on. With the TFIDFIS slightly modded has worked wonders. Instead of the TFI coil im using MSD Blaster 2 coils. A few problems that I have ran into are loose connections and corrosion. U get that under controle and it works flawless. Just my .02
Old Jul 26, 2011 | 01:17 PM
Jeff20B's Avatar
Lapping = Fapping
You need to look up DLIDFIS.
Old Jul 26, 2011 | 01:53 PM
Slave to the Rotor!
I'm just not a fan of the "cobbled together" look in my engine bay. Each ignition system has it's own pros/cons, I'm not trying to insult the "ignition gurus" here. Simply put a CDI box allows for rapid charge/discharge of the coil, which is beneficial for our high revving engines. Especially when using a dual post ignition coil that is firing twice as often as a single post DFI set-up.
The OP has enough info to make a decision for himself as to what set-up he wants to go with.
Me personally, I'll stick with MSD and a FC coil. It works, it's a clean install, and I've NEVER seen an MSD 6A go bad, unlike ignitors pushed to their limits.
Old Jul 26, 2011 | 02:24 PM
A.K.A. R-Cien
You have many valid points, over all the setups get the job done, what it comes down to is time and money. I know the FC coil with the MSD box is the most direct/easiest to install, but it's also a eye catcher to the cops, being that cops will associate MSD with racing. Now the 2GCDFIS and TFIDFIS sound great, but I don't think I have enough knowledge to build it and install it myself...
Thanks for all the info I have learned a lot, now to see if someone in San Diego is willing to help me gather and install this.
Old Jul 26, 2011 | 03:01 PM
Waffles - hmmm good
WTF! Cops look under your hood? Kalifornia the police state.
Good luck with whatever you decide to use. I'm not against MSD they just cost a
lot more than a DLIDFIS or TFIDFIS setup.
Old Jul 26, 2011 | 03:15 PM
patmac6075's Avatar
Once a Marine.....
Yeah....got to agree....what he said ^^^^
Trust me...doing the 2GCDFIS is super easy, and cheap. I did it it and it was really much easier to do than I originally thought. I wrote my own step by step instructions and would be happy to share them.
I'm not knocking MSD or TG Farrell's set up (like I said if/when I burn an igniter, I'm switching to TFIDFIS)...this was the path I took, and it was super simple.
pm me for easy to follow instructions.
Old Jul 29, 2011 | 12:09 PM
A.K.A. R-Cien
thanks for all the input guys
Old May 15, 2012 | 03:02 PM
Michael Murray's Avatar
Were can I find a wiring diagram for these mods?
meetRoX7e
Sep 11, 2015 11:09 AM
mulcryant
Sep 9, 2015 05:24 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
