Fuel tank swap, early to late?
Old Jul 14, 2011 | 02:03 PM
porkchop91's Avatar
Any complications with swapping the later fb detached pick up tank to a 82 fb?
What will I need to change? The sender is still located on the left rear wheel well
Old Jul 14, 2011 | 02:05 PM
82transam's Avatar
Never Follow
All 81-85 tanks are the same size and shape so it will bolt right in. Everything should just hook up the same way.
Old Jul 14, 2011 | 05:40 PM
74RX4's Avatar
Round and Round
Sorry to disagree, but that is not true. The 84-85 tanks are a different shape than the 81-83 tanks. The top section is wider on the 81-83 tanks and the 84-85 tanks are a little taller.. The car body is also different. The hatch floor between the left inside wheel well and the spare tire hole is about an inch wider in 81-83 than 84-85. We went through this several years ago. If you look closely at the 83 and 84 tank pictures on my website you can see that the top section is a slightly different size.
http://intertron.com/ron/tank.html
Here's a thread where we talked about it.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/gas-tank-628743/
Might be able to make a later model work, but not a direct bolt in. Earlier model will definitely not fit in 84-85 without modifying the body or the tank. Several of us have tried.
Old Jul 14, 2011 | 07:08 PM
ray green's Avatar
Gone
Yep I'll bet you'd get real frustrated trying to install a late tank to an early or vice versa. Besides the size differences that 74RX4 points out, I seem to recall reading somewhere they have different volumes and the sender units and plumbing are very different, as you can see from these photos. The 84/85 tank is on top, the 83 tank below
In fact I now have two tanks because I just picked up an 85 GS that didn't have a tank and although I already had the 83 tank shown above, I didn't want to mess with trying to install it in the 85 GS.
Fortunately Rotary Buddy Alex had just dropped the tank from his 85 FB race car to put in a fuel cell and he offered his 85 tank for the 85 GS project (the upper one in the pics). So kudos to Alex and I suppose karma dictates that I now find an earlier FB in need of a tank and donate the 83 tank, which originally came from Chris' white 83 GSL called Sexy Pants.
Old Jul 14, 2011 | 10:46 PM
350swapblzr's Avatar
I just put the early style tank in my 85 this spring it was tough to get the drivers side strap on but once I had a few threads started the impact took care of the rest. It doesn't seem to have crushed anything I also used the old style 2 pin fuel sending unit with the three pin plug in on my car and my fuel gauge actually works!!!
Old Jul 15, 2011 | 08:14 AM
82transam's Avatar
Never Follow
Sorry for the misinformation guys, I assumed that since they had the same capacity they were same. Weird that Mazda bothered changing the body like that. Good to know!
Old Jul 15, 2011 | 12:09 PM
Jeff20B's Avatar
Lapping = Fapping
I installed an 84-85 tank in my 81. It seemed taller so I used some longer strap bolts. Worked ok.
Old Jul 15, 2011 | 12:36 PM
74RX4's Avatar
Round and Round
Here are some pictures of the left side of the hatch floor showing the difference between a 83 GSL and a 84 GSLSE. I think the shape and/or location of the spare tire well is little different also. All the 84 and 85 cars I have (each model) measure the same. Can anyone attach pictures of 81 and 82?
Attached Thumbnails Fuel tank swap, early to late?-gt83.jpg   Fuel tank swap, early to late?-gt84.jpg
Old Jul 15, 2011 | 01:24 PM
82transam's Avatar
Never Follow
If I get a chance to toinght I can take pics of my 83
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
