Just bought a jspec 88 turbo exhaust manifold but...
Old Jul 14, 2002 | 11:10 AM
Hanzo's Avatar
Question Just bought a jspec 88 turbo exhaust manifold but...
I have a US spec 88 turbo II. What should I do? Looks like the waste gate actuator is on the wrong side. Does anyone know if it will work? If not I am sending it back to the seller.
Old Jul 14, 2002 | 01:48 PM
Aaron Cake's Avatar
Engine, Not Motor
Picture?
Old Jul 14, 2002 | 03:20 PM
Six Rotors's Avatar
If I recall correctly there are threaded holes on the front side and it is relatively easy to put your actuator on there.
Old Jul 14, 2002 | 03:34 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Just bought a jspec 88 turbo exhaust manifold but...
It's the twin-scroll actuator that's on the other side, not the wastegate.
Old Jul 15, 2002 | 05:55 AM
Hanzo's Avatar
Here is the one I bought:
https://www.rx7club.com/forum/showth...threadid=91888
Old Jul 15, 2002 | 09:50 AM
SaabGuy's Avatar
A friend of mine removed everything for the twin scroll crap. You can remove the flapper, rod, actuator, and then plug the exhaust hole and plug a single vaccum line. This will give you slightly more top end and slightly decreased bottom end, but its negligable.
Rip that crap off.
That looks like a nice clean turbo btw.
Old Jul 15, 2002 | 11:21 AM
Hanzo's Avatar
I am trying to make less modification and keeping it stock as possible. Any other suggestions?
Old Jul 15, 2002 | 11:47 AM
Aaron Cake's Avatar
Engine, Not Motor
That is the twin scroll actuator. Leave it on and assemble the manifold and turbo like your old one was...It will fit fine.
Old Jul 15, 2002 | 01:27 PM
Hanzo's Avatar
I bought the exhaust manifold.
Are we talking about the same thing? If the actuator on the exhaust manifold is on the wrong side how do I install it? Will it work as is? I am very confused.
Old Jul 15, 2002 | 03:41 PM
It will bolt right up and work fine. The actuator is just in a different location, but it all works the same. The only thing you may have to do is extend the vac line.
Old Jul 16, 2002 | 05:41 AM
Hanzo's Avatar
I am taking it to a mechanic so I wanted to make sure it will work with my US spec turbo II. I don't want him to take it apart and find out that it wouldn't work, then I will be charged for nothing. Since the actuator is on the other side will it physically fit in the spot? Will anything gets in its way?
Old Jul 17, 2002 | 05:51 AM
Hanzo's Avatar
So do I just ask the mechanic to bolt it right on? Or do I need to tell him to modify some part? I really need some answers here. Need to get the car running well again thanks.
Kyo
Apr 13, 2019 09:24 AM
Engine stand ready
Aug 14, 2015 10:26 PM
