Megasquirt Brief rpm signal then none
Old Jun 30, 2011 | 03:21 PM
GrammaRed's Avatar
ON Brief rpm signal then none
Megasquirt 1 with msns extra with zeal board
87 fc gxl with wiring tapped into the stock harness at the stock ecu so that I can swap back and forth between stock and MS until I get this thing running.
Attached are my msq as well as a datalog of my start attempts
Basically when I try to start the car I get rpm's briefly (2.5 seconds according to the log) then no rpm signal in both megatune and tunerstudio. I can't get an rpm signal again until I cycle power off/on.
Any idea whether I should be looking at my settings/wiring/board would be much appreciated.
File Type: zip
Old Jul 1, 2011 | 10:17 AM
Aaron Cake's Avatar
Engine, Not Motor
That is indicative of a missing second VR signal.
If you have a scope, you can trace the outputs of both VR conditioners.
Old Jul 1, 2011 | 08:19 PM
GrammaRed's Avatar
Bang on. Turns out I followed the instructions for MS2 and hooked up my vr2out from the zeal board to JS10 instead of JS8
Thanks Aaron
rotor_veux
Sep 19, 2015 07:13 PM
The1Sun
Sep 18, 2015 07:13 PM
Farkel
Sep 16, 2015 06:16 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
