Bizarre whine...
Old Jul 12, 2002 | 12:59 PM
Bizarre whine...
OK, my car whines... The faster I go, the higher pitched it becomes... I know it is always there when the clutch is engaged, I'm not sure if it goes away with the clutch in or not... I am thinking it is either the differential, the throw out bearing or the pilot bearing... Anyone care to hazard a guess?
Old Jul 12, 2002 | 01:01 PM
Matlock's Avatar
Check your supercharger J/k Those three things you mention are all possible. Check your belts thats an easy check.
Old Jul 12, 2002 | 01:05 PM
It's definitely NOT my belts... It's a constant whine, and it seems to come from under the seats, not from the engine compartment... How did you know I had a supercharger? (Actually, I have three, they feed off each other...) j/k
Old Jul 12, 2002 | 01:10 PM
Matlock's Avatar
Under the seats aaaa. Have you jacked the car up and (put jack stands under it) turned the car on. If you have someone to help you can put it in gear and rev it up a little to try to find it. It's hard to diagnose without being there. I would try investigating further unless you all ready have. Good luck.
Btw three superchargers dammm! That would explain the whine. hehehe
Old Jul 12, 2002 | 06:29 PM
I have a high piched whine whilst i'm driving its called Kate.
LoL,
Old Jul 12, 2002 | 06:39 PM
I wish I was driving!
Re: Bizarre whine...
You're right on the money with your diagnosis. My guess would center around Throwout bearing.
Old Jul 12, 2002 | 06:46 PM
First Give it a good service make sure all your oil levels are good, if it persists get it on a 4 arm ramp and get some one sat in it going through the gears (whilst running) then just stand under it and you should be able to hear where its coming from.
Ok does it make the noise whilst not moving or is it quiet then gets louder the faster u go? the genral rule is if the cars stoped the only parts moving is the engine and the Box so it will be one off those, if it happens whilst moving it will be any thing from the prop shaft back (Prop shaft,Diff,Drive,wheel bearings).
Old Jul 14, 2002 | 04:50 AM
Funklord's Avatar
my car does that, it makes a "whirring" sound when i drive or am in neutral without pressing the clutch. if i press the clutch it goes away. someone said it was a pilot bearing or throwout bearing.
Old Jul 15, 2002 | 11:26 AM
Thaniel's Avatar
Transmission bearings are wearing out. Time to rebuild. Rebuilt mine last year.
