what are the option for cradle or mounts for FD?
Old Jun 14, 2011 | 05:17 AM
87GTR's Avatar
what are the option for 20B cradle or mounts for FD?
Old Jun 16, 2011 | 05:48 AM
87GTR's Avatar
really? noone sells a engine mount kit or something like that?
Old Jun 16, 2011 | 06:51 AM
chohakai's Avatar
Defined Autoworks makes it. Check it out on their website. Logan is a regular contributor here as well.
Old Jun 17, 2011 | 06:30 AM
Banzai-Racing's Avatar
Rotary Specialists
Just buy a 20B subframe and drop the engine in. Do a little searching, there are several vendors and they are all listed in this subforum.
Old Jun 17, 2011 | 05:39 PM
hornbm's Avatar
FD > FB > FC
20B subframe or the defined auto works kit are your only off the shelf options. the defined autoworks kit being the better choice IMHO as it retains the factory subframe, and doesn't move the steering rack.
Old Jun 17, 2011 | 05:54 PM
87GTR's Avatar
Thank you for the great information. will the defined work with a RHD car?
Old Jun 26, 2011 | 11:28 AM
Prometheus's Avatar
Still got it.
I'll be using a dry sump front cover for my engine & run a 1/2" or 5/8" thick plate across the bottom of the engine.
If you extend the plate a bit in the rest, you can drill/ tap the plate and place studs in it (allowing you to retain your OEM motor mount location (some slight modifications will be made, but I'm okay with that.
It's a couple hundred dollars more than the option (which is the nicest non dry sump option, in my personal opinion) but you get to drysump your engine while you're at it.
Dry sump front covers can be had for around 2,500.00 USD (New)
http://rx7world.net/component/page,s...d,23/vmcchk,1/
Old Jun 30, 2011 | 02:17 PM
EllaMoto's Avatar
Do you mean the stock 20b subframe from the cosmo?
Old Jul 1, 2011 | 02:12 AM
hornbm's Avatar
FD > FB > FC
No idea, you could email them. They used to be a vendor on here but I'm sure a quick google search will bring them up. The only potential issue would be the added length of the motor, and if that impacts the steering collumn or not.
Am I insane for wishing the dry sump front cover still allowed you to use power steering and a/c?
Many companies sell a custom subframe that allows you to drop the 20B into a FD. The drawback is always the steering rack gets relocated. An actual cosmo subframe wouldn't work.
Old Jul 2, 2011 | 04:53 AM
87GTR's Avatar
LOL I was just going to ask if the cosmo subframe would fit. LOL I got 2 of them.
