Very Hard Water Spots
Old Jul 11, 2002 | 10:07 PM
Johnny's Avatar
OG
Clay magic was not good enough..
any other recommendations ?
Old Jul 11, 2002 | 11:11 PM
mazdaspeed00's Avatar
For Sale
gasp the clay bar didnt get it out? damn. i dont know what will then. try rubbin the clay bar harder if not try buffing
Old Jul 11, 2002 | 11:47 PM
mightyslash's Avatar
Will Work for Ferrari
I'm getting those too...Annoying as hell
Old Jul 12, 2002 | 12:01 AM
dclin's Avatar
Perpetual Project
If you are feeling brave, try the highest grit sand paper you can find (nothing less then 2000, if available) and *lightly* WET sand it. Wet sanding is applying water (or some sort of solution) to the sanding surface in order to lubricate and wash away the residue while you are sanding. Important to apply the solution continuously. A typical squirt bottle will work fine. Should dull the paint (clear coat) and remove the spot.
Be very careful not to break thru the clear coat. If you stay with a very high grit, you should be safe (unless you sand for a few hours, hehe).
Since you are just removing water spots, starting with and ending with the highest grit available should be fine. Normally with the painting/sanding process, you would start with a lower grit, and work your way up. Each higher grit removes the scratches from the previous grit, until you get to the point where you get a smooth dull finish - the basis for the rubbing/polishing process.
Follow up with rubbing compound, polishing compound, then wax. The Meguiar's 1,2,3 system works well for me.
I highly suggest taking it to a body shop though to have it done. Or get a fender from a scrap yard to practice on. It's an extremely scary idea if you've never done it before, but (with patience and practice) the results can be amazing. (and fun!)
Old Jul 12, 2002 | 12:16 AM
dclin's Avatar
Perpetual Project
I
I typically apply the rubbing compund, polishing compound, and wax with a polishing/buffing wheel (available at Lowe's/Home Depot) connected to a less powerfull (or adjustable speed) cordless electric drill when doing small parts. Since you are just doing spots, this should work for you too.
Using a high speed corded drill may cause you to burn thru the clear coat if you go crazy. Remember to apply LIGHT pressure.
Going back to the rubbing and polishing compounds, think of this as the 2nd and last highest grits. The rubbing compound will remove the scratches (which should be near microscopic by now, and only show as general dullness of the general area of paint) from the last wet sandpaper you used (again, nothing less then 2000, if not higher).
The polishing compound will remove any minute traces of dullness and provide the shine. The wax, of course, protects this.
Also, I keep two seperate polishing/ buffing wheels for the rubbing/polishing compound. I pair a buffing wheel (slightly rough - relatively) with the rubbing compound, and a polishing wheel (very soft) with the polishing compound.
Daniel
Old Jul 12, 2002 | 01:41 AM
Huy's Avatar
Huy
Newbie
Guys, take note, hard water spots can be removed easily with a vinegar and water solution.
Use a 50/50 mixture and spray it onto the surface...let it sit for a few minutes then wipe off. If the water spots are still there, apply more vinegar and let sit.
Once you are satisfied, I would suggest washing the car, then protecting the cleaned surface with wax...
I have used this method, as well as recommended it to others with 100% success.
Old Jul 12, 2002 | 02:08 AM
Nathan Kwok's Avatar
I've found just polishing is enough to get off bad water spots so you might want to try that before using sand paper.
Old Jul 12, 2002 | 04:16 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Just wet sand them out wit hsome 1500 grit and then buff it out. Or take it to the bodyshop and let them do it.
Old Jul 23, 2003 | 10:24 PM
wishbanzai's Avatar
Use "dri-wash" and SCRUB. It will protect from this happening again also.
Donald Hampton
16
Nov 23, 2022 06:38 PM
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
