No Idle Rx7 Gsl 1981
Old May 18, 2011 | 05:05 PM
Cullen26's Avatar
Hi everyone I just joined the rx7 club
My rx7 will start up and run with the choke on and run roughly but when it warms up
and the choke turns its self off and the car dies
Old May 19, 2011 | 11:08 AM
Kentetsu's Avatar
Good reading on carb adjustments: www.sterlingmetalworks.com
Old Jun 7, 2011 | 02:38 PM
Cullen26's Avatar
Sorry I have not replied for a while I had a mechanic who has never worked on a rotary engine before rebuild the carburetor but maybe he did it wrong but it was having the same trouble before it got rebuilt.
Old Jun 7, 2011 | 05:11 PM
Kentetsu's Avatar
Start looking into the ignition system. Begin by confirming that all spark plugs are sparking. Ignition issues often look like carb issues...
Old Jul 2, 2011 | 12:09 AM
maxwellt91's Avatar
Maxwellt91
I dont think it would be the ignition system because if it was the car would most likely not start at all with the choke on or off. Your idle speed or fuel mixture may not be set right. I would mess with your idle speed screw first and see if you can solve it
Old Oct 10, 2011 | 05:59 PM
Cullen26's Avatar
Now the car wont even stay on even if I try. It runs for about 10-30 seconds and dies. I try to keep it alive by pumping the gas pedal but it doesn't work I just here a air like sound that goes psst psst psst.
I took off the spark plugs and put Marvel Mystery Oil into the engine and let it sit for 24 hours.
I started it up making the biggest white cloud come out of my tailpipe. The car died a few times but after 5-10 minutes it was running a lot better and actually idled with
smoke coming out of the I think catalytic converter or exhaust manifold but after about another 10 minutes it would not idle but it did run.
So the next morning I try to start it up and I could not keep it running for a minute unless I pumped it 20 times. I also cleaned the spark plugs.
I checked through the window of the carburetor and it was empty
So I am now guessing this is a ventilation issue, Carburetor issue, or a vacuum leak I cannot find. I will maybe try to adjust the carb but my tachometer went out when I hit a bump.
Old Oct 11, 2011 | 04:55 PM
Kentetsu's Avatar
Could be the fuel pump, can you hear it running when you turn the key on?
Old Oct 11, 2011 | 04:58 PM
Kentetsu's Avatar
Wrong...
A freind and forum member Man in Black installed a new motor and came by to show me. The thing sounded like it was ported, but it wasn't. Ran like a raped ape, but felt funny at the top end. I looked it over and saw that he had leading and trailing reversed on the rear rotor.
A couple of years ago, after a fresh motor install, car was running fine but I was having a tough time eliminating spark knock at high rpms. That was my only indication of something wrong, and it was barely noticeable. Eventually found that my ignitors were running to the wrong coils, so leading and trailing were reversed. I actually won a few autocrosses like that.
So yeah, you can totally screw up the ignition wire routing and still have a car that runs "almost" right.
Old Oct 11, 2011 | 06:29 PM
BASTARD's Avatar
First check that you are getting fuel...
always be careful when working with gas/fuel... always disconnect the ignition to keep it from sparking an explosion.
disconnect the fuel feed line line at the carb and place in a catch bottle
turn the key to the on position and see if fuel fills the catch bottle
if it doesnt fill the catch bottle, you have a fuel feed problem... bad pump, clogged line or filter or out of gas
if it does fill the bottle... then re-connect the fuel line and check float bowl levels, they should be in the middle of the sight glass (check both floats)
if no fuel in float bowl you will need to take the carb apart to verify the needle and seats are working
if you do have fuel in float bowls, then check accelerator pump, you should see fuel spraying into the primaries every time you actuate the throttle
if you dont see fuel spraying in, you either have crap in your carb or a bad accelerator pump... carb needs a rebuild with a quality rebuild kit from a mazda parts store like mazdatrix
if all of that checks out, check for vacuum leak... you probably have a vacuum leak from the joker who previously rebuilt and/or installed the carb.
.... you will need a new set of plugs as your old ones are surely fouled beyond foulness
Old Oct 12, 2011 | 06:20 PM
Cullen26's Avatar
Its a new fuel pump and I can here it when the key is on
Old Oct 12, 2011 | 07:09 PM
Cullen26's Avatar
So I tested the fuel line by putting it in a bottle and turning on the key and there was gas being pumped into the bottle.
The mechanic told me that the carb does have a broken accelerator pump
I know the spark plugs are fouled but I do clean them but I should probably get a new set.
How do I check both float levels? Can you see them both through the window on the carb?
I checked the window and it is usually very low
I could not get my car stared because my battery is a little weak but right now the level is below half.
Last thing what is a good way to check for vacuum leaks?
Old Jun 9, 2012 | 10:11 AM
Cullen26's Avatar
Many months late I've found the problem. It was just a pinched gas line. I also put on a different (used) carburetor but now it idles at 2000 and warms up at 4000 and when I turn it off it backfires like a 12 ga. any suggestions on what I should do?
Kyo
Apr 13, 2019 09:24 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
kenplevy
Sep 4, 2015 10:40 AM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
