Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
Need somones help
Old May 18, 2011 | 03:38 PM
shawnm565's Avatar
MN Need somones help
Hey I was wondering if anyone in the MN area who has experience with the stock twins to listen to what my turbos are doing, iv asked people and had people ride in my car and no one knows, I live in monticello, and I just got the car about a week ago.
Old May 18, 2011 | 04:03 PM
Force13B's Avatar
No more G6
Can you explain it or post a video?
Old May 18, 2011 | 05:15 PM
shawnm565's Avatar
Yea I will try to get a video tonight
Old May 19, 2011 | 12:29 AM
Turblown's Avatar
Turn up the boost
We aren't far from you. Just give us a call we can check it our for you..
Rotary Performance Parts
Old May 19, 2011 | 03:53 AM
Rocking Rotary's Avatar
If there is a problem with them it should be fairly obvious on whats going on. Ie ate up turbine , leaks or blows lots of oil. Turbos are fairly simple machines.
Did you buy the car localy?
Old May 19, 2011 | 10:01 AM
shawnm565's Avatar
Well I figured out what my problem is, the car has a 3 inch down pipe, hks intakes, and a larger intercooler, and well I still have a stock ECU. If I keep the car at 10 lbs boost it will not cut at all, but if I smash the throttle, the boost tends to spike to 15lbs and when that happens, it cuts. I beleive it is a fuel cut and I need to get a manual or electronic boost controller and probly a new ECU and then get it tuned.
I bought it from hastings MN
Old May 19, 2011 | 10:32 AM
Force13B's Avatar
No more G6
Stock ECU with your mods anything over 10psi is playing with FIRE. Get your boost down or you'll be looking for a new motor here very soon.
Old May 19, 2011 | 10:53 AM
shawnm565's Avatar
oh I know... she is going to sit until I can get a boost controler
Old May 19, 2011 | 04:10 PM
You should not have a boost spike like that if the stock main cat is in place. Other wise you may have a vacume issue. Also a boost controller may not help the issue with twins. The only real solution I have found is to port the wastegate and area around it. These cars also do not have a fuel cut what your feeling is detonation. Do not keep doing that! A power fc helps but with your mods the stock ECM will work for now.
If it's the red fd with the white front bumper I know the one your talking about. I did the rebuild on the motor a few years back. It was set up sequentially and running like a top last time I saw it.
Fennix_sr
Apr 27, 2003 11:14 PM
spoolage
Nov 2, 2002 03:37 PM
MattZeeTerror
Mar 31, 2002 09:43 AM
RX7_Racing2001
24
Dec 11, 2001 08:52 AM
nitrouspeed2
Sep 16, 2001 08:38 PM
