RPM's drop alot when A/C is on???
Old Jul 11, 2002 | 01:01 AM
sjh62's Avatar
Newbie
Question RPM's drop alot when A/C is on???
Can anyone help?? I have a 1987 RX7 with auto. When I turn on the A/C the rpm's drop. If I'm at a stop light the engine dies. I have a shop manual and cannot find anything about this. It seems to me that the BAC valve has something to do with raising the rpm's. Is that so??
Or is it a function of the cpu?? If anyone knows anything about this, please respond - it is really hot here (Las Vegas) !!!!
Old Jul 11, 2002 | 01:03 AM
dre_2ooo's Avatar
Yes that's true. Most likely your BAC is bad...
Old Jul 11, 2002 | 02:16 AM
TonyTurboII's Avatar
Glock Lover
Try removing the BAC valve and cleaning it. Test the resistance also. If its out of spec replace it.
Old Jul 11, 2002 | 05:28 PM
vaughnc's Avatar
knowledge junkie
Lastly check the TPS (throttle position sensor) to verify it's working / calibrated correctly.
Have a good rotary mechanic do this if you're not sure. DO NOT!!!! take this to the mazda dealership.
Old Jul 11, 2002 | 05:31 PM
rico05's Avatar
WTB S5 N/A FC
I had the opposite problem before the TB mod. A/C off, idle was 200 rpm. A/C on, idle was perfect at 750 RPM. Damn overacheiving BAC! Pull off the BAC and use a can of brake cleaner all in it until the fluid comes out clean. Good luck!!
Old Jul 11, 2002 | 08:45 PM
HAILERS's Avatar
HAILERS
Read this article: http://www.teamfc3s.org/info/articles/idle.html
Read the part about the bac. This article, as far as the bac goes, is not dependent upon whether you have a NA or a Turbo.
One of two things is probable. One is that your bac signal is missing from the ECU. And the second most popular is that the idle of your car is not set correct. Go for the first and read the article at: http://www.teamfc3s.org/info/articles/idle.html
Old Jul 11, 2002 | 10:15 PM
brap brap
Well, the a/c does take a significant amount of power when it's turned on. You need to add a little more extra gas than you do with it off. I have the same problem - but adding more throttle (just a tad) really does wonders. There could be a problem, to my knowledge, I just think it's because the a/c eats up a bit of power, which is why most heavy duty modders here have taken their a/c out, etc....
Old Jul 11, 2002 | 10:48 PM
Six Rotors's Avatar
Well of course A/C uses some extra hp.,that's why the BAC is supposed to open some when your A/C is turned on.If everything is set up and working you should see a 50-100rpm increase when you turn on your A/C.Follow Hailer's advice.
Old Jul 11, 2002 | 11:23 PM
NZConvertible's Avatar
I'm a boost creep...
You shouldn’t need to, the ECU should instruct the BAC valve to do this for you. My engine has a smooth 750rpm idle; with the A/C, headlights, rear demister, interior fan, and windscreen wipers on it sits at 800rpm. The engine sounds loaded (coz it is!) but it’s still smooth.
Old Jul 31, 2002 | 05:49 PM
my engine idles at 1200 no matter how much I try to udjust it doesnt change plus I've already set the TPS when I turn the A\C on it idles down to 750 800
rx7jocke
72
Jun 17, 2016 03:48 AM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
gabescanlon
Sep 5, 2015 12:09 AM
