1985 13b motor
Old May 12, 2011 | 04:07 PM
Unkleg's Avatar
1985 13b motor
Hello all,
I am new here and I am at a lost on where to go. I have a 1985 13b motor in my Manx and about 3 weeks ago it runs but trouble. I thought it was the gas I had just put in it that day so I drain all the gas, cleaned all the filters and added new fuel in it. I started it and the samething happened so I thought it may need a tune up so I put in all new plugs new cap new rotor new wires. Started it and still the same thing. So I have no idea where to go next.
So now to my question I live is San Diego Ca and need to know if anyone knows of a mechanic in my area that still works on older 13b motors I have called several places and no one I have talked to can find someone that will work on it.
So I am asking you help.
Thanks
Greg
Old May 12, 2011 | 11:56 PM
rxtasy3's Avatar
need more info than "my 13b runs bad, what's wrong with it". could be anything from trash in the carb to a blown apex seal. vid would help.
Old May 13, 2011 | 08:50 AM
Unkleg's Avatar
It sounds like the timing is way off. Spits and sputters and back fires. Give it any throttle and you have NO power at all.
Old May 13, 2011 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Carbureted or fuel injected? We need at least some info here to offer advice...
Old May 13, 2011 | 07:04 PM
Unkleg's Avatar
single 48mm side draft Carburetor
Again I am just looking for a mechanic in the San Diego that works on older rotary motors.
Old May 20, 2011 | 10:35 PM
treceBturbo's Avatar
i have a problem ad i was wondering if anyone can help...i asked everyone and no one knows how to help me....ok i had a RB holley 600 for my rx3 13b bridgeport. but both floats broke, and it got thrown out. un fortunately.
So... i bought a regular holley 600 cuz i had a limited amount of money. now my car runs fine at idle but as soon as u floor it..it floods and it runs pig rich at cruise. i reallly just want to know how to fix this, what do i need to do..im a rotary noob and im trying to learn as much as possible. thanks
-eddie.
Old May 20, 2011 | 10:36 PM
one more thing...what are these weber jet plates i been hearing about? what are the pros cons etc? thanks very much
-eddie
Old May 21, 2011 | 08:39 PM
snivley whiplash's Avatar
brappppp brappppp
Greg,
pull the jet cover and remove the jets and clean them with carb cleaner and reinstall. replace the fuel filter and make sure you have good fuel supply. my dellorto side draft is really unkind to anything in the fuel system, I run two fuel filters to help with the problem. sounds totally fuel related.
Old May 22, 2011 | 11:49 AM
Unkleg's Avatar
Originally Posted by snivley whiplash
Greg,
Boy I can't believe I did not think of this.
Thanks for the tip Snivley. FYI I am now running with 2 filter also.
I guess everyone forgets things at times.
Old May 22, 2011 | 11:52 AM
brappppp brappppp
hope this helps sent pm
turbo-minivan
69
Feb 4, 2016 12:29 AM
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
turbo-minivan
Aug 27, 2015 07:56 AM
dludden
Aug 26, 2015 11:25 AM
