Megasquirt launch wiring
Old May 12, 2011 | 01:03 PM
gabs88gxl's Avatar
Retard
launch wiring
Im looking around on how to wire the launch control in to my 2.2. I seen that you us jp1 pin 4. how do i run this do i run pin 4 to a swtich an a ground to the other side of the switch. or do i have to run in to the board. Using a input jp1 pin 4 and a output some where in the board. please let me know thank you
Old May 12, 2011 | 03:39 PM
papiogxl's Avatar
What's the point??
This circuit is what you would build.
Old May 16, 2011 | 01:15 AM
gabs88gxl's Avatar
Retard
so do i just take the wire from jp1/4 to the switch n take the resistor an the diode to the tps 5verf
Old May 17, 2011 | 01:43 AM
FC3Sdrift's Avatar
Displacement Replacement
can you use the 5v from the proto area?
what about the zeal daught would the inputs work on that for launch control???
i've spend over 4 hours tonight readin about this
Old May 17, 2011 | 03:34 PM
gabs88gxl's Avatar
Retard
thanks a good question cause that will use less wire ill talk to ken or someone at diy maybe they can help us out
Old May 17, 2011 | 04:37 PM
FC3Sdrift's Avatar
yeah i' like to figure it all out, I have the diodes and resistor, i just dont want to go and start messing with stuff and fry something
Old May 18, 2011 | 12:30 AM
gabs88gxl's Avatar
Retard
thank you atleast im not the only one with that fear
Old May 18, 2011 | 05:38 PM
SPIRITED_DRIVER07's Avatar
Never Enough Turns
I also have been wondering the same thing
Old May 18, 2011 | 06:08 PM
FC3Sdrift's Avatar
HaHaHa i was like "sweet someone new replied maybe they know" guess not
Old May 18, 2011 | 06:19 PM
gabs88gxl's Avatar
Retard
well i got it i talked to matt at diy today an we kind went over it. Pretty much just get two diodes the 1n4001 an one 2.2k resistor. run it like the diagram but run it to jp1 pin 4 an if you are using the zeal board you can jump off the 5volt or jp1pin 8 put that bad boy in an boom it worked lol. ill make a little write up to help out
Old May 18, 2011 | 08:50 PM
FC3Sdrift's Avatar
if i can use the 5v off the zeal board i take it i can use the 5v from the proto area??? to keep it cleaner
Im using the 3.0 board
i'll just build it and see how it works
Old May 19, 2011 | 02:48 AM
gabs88gxl's Avatar
Retard
yeah im pretty sure as long as its a 5volt it will work just make sure u use the resistor an the diodes. cause even with mine ran to the 5volt on my zeal i push the push button an launch lights up on the bottom of megatune.
Old May 19, 2011 | 08:10 AM
papiogxl's Avatar
What's the point??
5v is 5v as far as the ms is concerned, especially for this circuit. The ms just needs to see the voltage drop from 5 volts to (essentially) zero.
Old Jun 25, 2011 | 06:51 PM
.::evil inside::.'s Avatar
Did you end up putting a little writeup together? I haven't touched my ms for a while and my brain isn't computing how to build the said circuit. Pictures would help me greatly even pics instead of writeup would be awesome.
Old Jul 6, 2011 | 04:36 PM
FC3Sdrift's Avatar
i finally got around to making the launch circuit
heres a little video i made trying it out at 4k
http://www.youtube.com/watch?v=EyNxuNdraAY
Old Jul 7, 2011 | 08:51 AM
nice work mate.
Any pics?
Old Jul 7, 2011 | 10:42 AM
FC3Sdrift's Avatar
this is how i set mine uop in my proto area, its basically what the diagram shows to do
Old Jul 8, 2011 | 04:55 AM
Thanks for that mate, so the switch is connected to ground?
Old Jul 8, 2011 | 09:35 AM
FC3Sdrift's Avatar
yeah, just grounds out the circuit
i forgot to say i just used the spare pin aaron cake uses for his E fan circuit, goes to pin 25 on the db37
Old Jul 9, 2011 | 01:20 PM
Geez, can't believe I even needed to ask those questions. My brain really is out of gear, thanks for putting up with my momentary stupidity.
would you be able to post a screen capture of your launch/flat shift settings?
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
