Coolant tank neck crack
Old May 12, 2011 | 12:21 AM
denizpa's Avatar
Hey all,
I noticed some coolant coming from the passenger side corner of the R1 lip. It seems that the neck of the coolant reservoir has a crack in it, big enough to lose coolant during spirited driving.
I was wondering if someone could recommend a reliable source for getting a replacement coolant tank from, and in general a good source for rx7 parts.
Also, I plan on doing this on my own, so if anyone has a writeup, that would be very useful.
Thanks,
Deniz
Old May 12, 2011 | 10:04 PM
gracer7-rx7's Avatar
needs more track time
Read the 3rd gen FAQ thread. In there you will see contact info for Ray Crowe - Parts Manager at Malloy Mazda. He gives us discounts on stock parts and owns 2 FD RX7s.
RX7.com is also a great source but more for aftermarket and performance parts.
Old May 13, 2011 | 04:54 AM
Sgtblue's Avatar
Urban Combat Vet
If you need it, I absolutely second Malloy Mazda. Ray in particular, but I've also had good service from others there in the parts dept. if Ray happens to be out. Quick shipping and fair pricing.
Once your post count is up, there is also the 3rd. Gen Parts For Sale section for used parts. You can also post a Want to Buy (WTB).
As for a write-up, that's one of the few things I've never had to mess with, but if it's like the windshield washer tank on the opposite side, you just need to pull the RF wheel and fender liner off to access. Fender liner has some plastic retainer clips. Nothing hard, but take your time removing them so hopefully they can be re-used. If not, the local parts store should have replacements. Probably a couple of 10mm bolts holding the tank.
If you haven't yet, go to the 3rd Gen. Section and download a copy of the Factory Service Manual (FSM ) and it should give you more info.
ZaqAtaq
Sep 5, 2015 08:57 PM
