Short shifters for sale...
Old Jul 10, 2002 | 10:08 PM
TwinTriangles's Avatar
What's an RX-7 ?
I had one in my old sec. gen. and I gave one to my friend RX7Kevin, if your interested I will make them to order, I dont have any pre-made so it will take me about a day each...
Old Jul 10, 2002 | 10:17 PM
How much are you asking for one?
Old Jul 10, 2002 | 10:57 PM
autocrash's Avatar
Now with more 1st Gen!
interested for sure, but at what cost?
Old Jul 10, 2002 | 10:59 PM
Cheers!'s Avatar
Former Rx7 *****
which tranny? N/A or Turbo tranny?
Old Jul 10, 2002 | 11:40 PM
jspecracer7's Avatar
1JZ powered
Cheers...That's an AWESOME AVATAR!!!
Old Jul 10, 2002 | 11:43 PM
autocrash's Avatar
haha.. I found that picture, it's an RX-7 that flew off the freeway (in florida if I remember correctly) and hit a tech college or a highschool computer room or something....
....benefits of working at a newspaper....
Old Jul 11, 2002 | 12:17 AM
AreExSeven's Avatar
Huh?
actually, it was california. Roseville California to be exact. My home town
Old Jul 11, 2002 | 12:21 AM
Ryde _Or_Die's Avatar
Whats the price looking like? Man, wheres the dedication? Its been over 2 hours since this was first posted
Old Jul 11, 2002 | 12:58 AM
autocrash's Avatar
Picky picky picky... I can't remember ok.... I get the two mixed up ...lol... it's been awhile since I read the cutline for the photo....
Old Jul 11, 2002 | 01:15 AM
Juan's Avatar
Im a tall midget.
Are these actual short shifters? Or did you just cut and rethreaded the lever?
Old Jul 11, 2002 | 02:11 AM
TonyTurboII's Avatar
Glock Lover
It doesent really matter. Either way, the pivot point is moved to a different point in the axis.
Old Jul 11, 2002 | 02:30 AM
RETed's Avatar
If you're talking about modifying the stock shift lever...no, it's not.&nbsp You're just shortening the top lever length as referenced to the pivot point; the opposite/shorter lever that engages to the shift "linkage" to pivot point length is still the same.&nbsp All you did is cut the shift lever height and increase the force needed to shift the shifter.
A true short shifter moves the pivot point in reference to both ends of the shift lever.&nbsp Shift force is kept close to stock if designed correctly.
If these guys are indeed trying to sell rethread stock shift levers without the top isolated piece removed, you're getting ripped.&nbsp Anyone can heat the stock shift lever and instant short shift lever.&nbsp Depending on your choice or (aftermarket) shift *****, you may or may not need to rethread the rod.
-Ted
Old Jul 11, 2002 | 02:33 AM
Glock Lover
Hm. Guess I was wrong. Now you got my wheels turning.
Old Jul 11, 2002 | 03:00 AM
Juan's Avatar
Im a tall midget.
Originally posted by RETed
If you're talking about modifying the stock shift lever...no, it's not...
-Ted
Ted took the words right out of my mouth. Ive seen "short shifters" on ebay and theyre the stock shifter with the top sawed off. Thats why I asked to make sure bout this product.
Old Jul 11, 2002 | 07:54 AM
Cheers!'s Avatar
Former Rx7 *****
actually the avatar is stolen off stonePETER at teamfc3s.org/forum...
i hope he doesn't mind... hahaha
Old Jul 11, 2002 | 01:03 PM
airbrush1's Avatar
ted,
If I wanted to heat my stock shifter and bend it to make a short shifter, which way, and how much would i do it? if it works alot of people would probably do it, might be worth a write up
Old Jul 11, 2002 | 03:11 PM
Glock Lover
I dont think bending it would help anything.
Old Jul 11, 2002 | 03:20 PM
KNONFS's Avatar
B O R I C U A
Originally posted by airbrush1
ted,
It is very easy:
1-Remove the shifter
2-Notice that the shifter is made out of two sections (lets call them the top part and the lower part)
3-Use a torch to heat the section were the top part and the lower part joins.
4-Use two vice grips (one in the top part and one in the lower part) and pull them apart.
5-Make some thread in the lower part and VOILA!
Notice that this a very unconfortable mod (if you can call it a mod), I went back to the OEM setup in a matter of hours. The throw doesn't feel "short" at all, and IT IS HARDER TO SHIFT!!
Old Jul 11, 2002 | 03:29 PM
I didn't have to heat thre shifter on my old NA. I just took some vice grips, locked on the top part and twisted the top off. It will be a little harder to shift but I think that was mostly due to the fact that I need some new tranny fluid and my clutch was almost all the way gone.
Old Jul 15, 2002 | 12:52 AM
autocrash's Avatar
so..uhm... still no prices??
Old Jul 15, 2002 | 03:09 AM
Juan's Avatar
Im a tall midget.
I think they were stock shifters that were cut otherwise this person would have said something already.
Old Jul 15, 2002 | 09:33 AM
Phu5ion's Avatar
I'll have a Coke!
Originally posted by KNONFS
It is very easy:
not too mention that the rubber between the two sections is ment to reduce vibration. without that the only person who is going to be happy with this "mod" is our girlfriends .
vibration... girlfriends... get it?
Phu5ion
msilvia
164
Mar 8, 2020 08:00 PM
