won't start
Old May 10, 2011 | 08:40 AM
aeagles's Avatar
won't start
88tII turns over fine, just no hint of a start. pulled plugs not wet. can't hear fuel pump, but last time running i could not hear it . was wondering if there is a starter solenoid relay on these cars & where it is located. sorry to sound so dumb, any help is appreiated.
Old May 10, 2011 | 04:45 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The starter is not the issue if it turns over. That would mean the starter solenoid is being energized, and the gear is meshing with the flywheel.
You can check fuel pressure with an in-line gauge. The fuel pump can also be forced to run whenever the key is 'ON' if the yellow 2-wire test connector on the passenger strut tower is jumped. Fuel pump voltage can be tested at the pump harness.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
