cheap hp and help!!!
Old Jul 10, 2002 | 03:48 PM
sweetege's Avatar
bzzzzzzzzzzzzz
My first question is how can i get cheap hp will spend up to $100, and my second is my rim is bent or more liked smashed on the edge so is it still ok to drive on the interstate. i have an 84 gsl-se.
thanx, sweetege
Old Jul 10, 2002 | 04:20 PM
1_dollar_83_RX7's Avatar
i assume you want to go faster? remove weight..search for weight.
get a K&N air filter they are around 40$ it helped me a little
make sure everything is tuned up
remove ps, a/c and power fan if you don't want any of them they are just taking away hp and adding weight.
people will tell you to remove emmisions and air pump, but i don't recommend it.
no clue about the rim
Good luck
Old Jul 10, 2002 | 04:29 PM
Project84's Avatar
Open up! Search Warrant!
pics of the rim would help.
Old Jul 10, 2002 | 05:55 PM
Leshrak's Avatar
100 bucks is fairly limiting HP wise.
Fun stuff wise you might want to look into:
Nikki Carb mod write up from Sterling
Ghetto cold air
DLIDFIS
Junkyard electric fan
Weight reduction
All fairly cheap mods.
Old Jul 10, 2002 | 06:02 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by Leshrak
Nikki Carb mod write up from Sterling...
GSL-SE = Fuel Injection, No Carb, No Nikki.
No Soup for you.
Old Jul 10, 2002 | 06:05 PM
lol
Old Jul 10, 2002 | 06:16 PM
jeremy's Avatar
male stripper
No Soup for you.
ohhhhhhhh!!!!!!!!!!!!
if you do drive the rim on the interstate, don't fly and be very weary of it. as for horsepower, what they said.
Old Jul 10, 2002 | 08:12 PM
sweetege's Avatar
bzzzzzzzzzzzzz
here is a pic if it works, the tire is now in the right front.
thanx, sweetege
Old Jul 10, 2002 | 11:00 PM
I am a Jeeper Now.
thanx, sweetege
The right Rim shop should be able to fix that up for ya.
Old Jul 10, 2002 | 11:13 PM
REVHED's Avatar
Hunting Skylines
About the rim, a good rim repairer should be able to fix that pretty easy. If need be they can cut the offending piece of rim off, weld it up and machine it back to the way it was.
Old Jul 11, 2002 | 12:06 AM
adssoccer's Avatar
check the 5th and 6th port actuators. go look at the thread in this forum called "6port running on 4" thats FREE hp right there if you can get them to work. what other mods do you have?
Old Jul 11, 2002 | 09:26 AM
sorry wrong id
Old Jul 11, 2002 | 09:29 AM
sweetege's Avatar
bzzzzzzzzzzzzz
sorry wrong id at first. I don't have any other performance parts yet only lightening (taking parts off in case i spelled it wrong) might do direct fire.
thanx, sweetege
Old Jul 11, 2002 | 12:00 PM
adssoccer's Avatar
if i were you, i'd save up another $80 or so and go buy a header. exhuast is the best way to get more hp, after a full exhaust i'd think about intake, i'd definitely wait for direct fire until you have more mods like full exhaust and aftermarket carb or something. if you NEED new ignition parts, just get the ngk stock replacements, they work great. taking off the a/c is easy and free hp. one thing i did was send my fuel injectors out to be rebuilt/balanced/blueprinted. it costed $75, but i think it was worth it. the engine runs smoother and stronger, especially in the midrange rpms. but it's a chore to get to the fuel injectors and the car will be out of commision for a week or so.
Old Jul 11, 2002 | 07:29 PM
Blackrx71's Avatar
I have a full set of SE rims will take $100.00
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
Captain Hook
Sep 22, 2015 01:12 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
