Do i need this attached?
Old Apr 28, 2011 | 05:03 AM
Buzza's Avatar
Series 5
Question Do i need this attached?
I've removed the heat soaker stock intercooler and installed a FMIC still running stock computer and AFM with a pod,there was a big hose that connected from the intake manifold to the stock air box but now i have no where to run it into... help
when the car is turned on i've noticed that the hose sucks in air so is it ok to just leave it disconnected or do i have to somehow connect it to the pod or can i just put a mini filter on it? any suggestions would be a big help because i use the car everyday thanks.
Attached Thumbnails Do i need this attached?-img_0175.jpg   Do i need this attached?-img_0170.jpg
Old Apr 28, 2011 | 08:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I take it you mean the BAC inlet? You need to route that back into the intercooler piping. The ECU will not be happy with all that unmetered air, and it will probably result in idle problems. You're also sucking unfiltered air into the engine right now.
Old Apr 29, 2011 | 12:39 AM
Buzza's Avatar
Series 5
yes i have been getting some idle problems do i have to run it back into the piping before the AFM or after that?
I've purchased an apexi filter with an attachment to it when i get it ill attach it to that but for the mean time can i just put a mini filter on it?I'm guessing it will be better than just sucking unmetered air?
Is it ok to drive or am i going to have some problems,what can go wrong?
Attached Thumbnails Do i need this attached?-img_0178.jpg   Do i need this attached?-img_0179.jpg
Old Apr 29, 2011 | 06:58 PM
Top Down, Boost Up
Unmetered air means air pulled in after the AFM, so the ECU doesn't know about it. I think you mean better than unfiltered air.
You need to route the BAC inlet after the AFM. Look at how it was connected in stock form.
Old Apr 30, 2011 | 06:05 AM
Buzza's Avatar
Series 5
thanks,i understand that i was just asking what would go wrong and if its bad for the engine to run it without it being connected etc. can you explain why its bad?
I've put a mini filter on the end of it and when i get the new proper one thats in the picture i'll connect it to that one.
Old Apr 30, 2011 | 10:22 AM
Aaron Cake's Avatar
Engine, Not Motor
Air is entering the system which has not been metered with the AFM. That will throw A/F ratios all out of whack.
ANY air entering the system (BAC, BOV, etc.) needs to be connected AFTER the AFM.
Old Apr 30, 2011 | 08:36 PM
Buzza's Avatar
Series 5
Thats only if your using the afm and stock ecu correct?
If your running an aftermarket ecu then you dont need to run the afm?
Old May 1, 2011 | 10:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Correct. The stock ECU needs the AFM, but most standalones do not require an AFM.
Old May 1, 2011 | 06:15 PM
Buzza's Avatar
Series 5
In the future when the standalone comes will I have to block that bacv off or will I still need to connect it to the piping?
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
DC5Daniel
SE RX-7 Forum
Sep 29, 2015 07:50 AM
rx7dky
Old School and Other Rotary
14
Sep 23, 2015 12:47 PM
