thermostatic fan switch
Old Jul 9, 2002 | 09:28 PM
ASEmaster's Avatar
Those of you running electric fans with a thermostatic switch to turn it on/off.. what type of switch are you using and exactly how is yours hooked up?
I just tried the Perma-cool that uses a probe you stick in the radiator fins, but I'm sending it back because the POS wouldn't ever turn on, even on the lowest temp setting. Now I've got a Flexalite coming with a sensor you stick in the upper radiator hose... anyone got that one?
What temp do you all have yours set to turn on at?
If you use the threaded sensor kind, where do you thread it in at?
Old Jul 9, 2002 | 10:01 PM
setzep's Avatar
Kind of a funny question comming from a ASE Master??
Put the temp switch in the water pump housing under the thermostat so it reads actual engine coolant temp.
Old Jul 9, 2002 | 10:12 PM
REVHED's Avatar
Hunting Skylines
I'm using one with the sensor located in the upper radiator hose and it works perfectly.
The temp that you set it to come in (assuming you have an accurate guage) will depend on your thermostat rating. I've only got the crappy stock guage so I set the fans to come in just above normal highway cruising temp.
Old Jul 10, 2002 | 11:19 AM
mar3's Avatar
Administrator
The Derale comes with a sensor to be stuffed into the fins of the radiator, also. It works perfectly. Derale...good stuff, maihn...
Old Jul 10, 2002 | 06:03 PM
ASEmaster's Avatar
I'm a certified master engine machinist.. not an auto technician (yet ) Unfortunately there was no Rotary Engine section on any of the tests!
RevHed, did you silicone around the wire protruding from the radiator hose, or just crank down the hose clamp really tight? (or both?)
Old Jul 10, 2002 | 07:51 PM
REVHED's Avatar
Hunting Skylines
Mine came with a little ( shaped rubber grommet that sits between the hose and the metal inlet pipe. It has a groove cut into it that the sensor wire sits in so you basically just crank the clamp down. It's yet to leak on the two years I've had it on there.
Blastfastrotary
Sep 11, 2015 12:26 AM
