Can streetport pass CA smog
Old Jul 9, 2002 | 09:08 PM
riptyde's Avatar
The Addiction of Wankel
Question Can streetport pass CA smog
I'm planning on getting a rebuilt engine from Atkins rotary and I was thinking about porting it. I was wondering if anyone has streetported their engine and passed CA smog.
Old Jul 9, 2002 | 09:09 PM
ACTION RT's Avatar
G35 FTW
No, probably not....
Old Jul 9, 2002 | 09:21 PM
AreExSeven's Avatar
Huh?
Anything is possible if you have the right friends (hint hint)...
Old Jul 9, 2002 | 10:38 PM
Rpeck's Avatar
What R U thinking self?
If you have a aftermarket (configurable) ECU, or a add on "clean chip" for your current ECU it can pass. Thats how I am doing it. I have 2 chips for my ECU a "clean" and a highly modded.
Old Jul 9, 2002 | 10:40 PM
j9fd3s's Avatar
Community Builder
if the air pump and acv are working with both cats you might be able to squeek by. its gonna need everything the stock smog system can dish out though
mike
Old Jul 9, 2002 | 10:54 PM
BDoty311's Avatar
88 AE
I agree with areEXseven that knowing good people helps. Personally i went downtown and this guy did like a 1 minute inspection.
Old Jul 9, 2002 | 11:30 PM
jmseven's Avatar
Asset is Wealth
In California, you WILL find some smog shops that do not know ANYTHING about the engine layout. If you have black headers or downpipe, they cannot tell. If your car is LOUD, then they will take there time to inspect it. They have the right to reject your car.
From personal experience, I noticed that OEM looking mods do NOT have problems. There are people here that have mild street ports and have passed.
Old Jul 9, 2002 | 11:50 PM
Rpeck's Avatar
Ya, I don't think passing a visual inspection will be a problem (lots of dipships out there) But passing the snorkel test is going to take a ECU change i'm telling ya.. you can't very easily bluff a california emissions snorkel test. That computer they use plugs directly into the California DMV emissions computer system... they use a scanner to scan your regisration paperwork .. it tells the make model & history of the car. They compare the VIN# to the paperwork .. and in 80% of the California counties now you have to do a "smog check II" that means a Dyno machine with the snorkel n the pipe. Unless you are VERY hooked up .. and somone is willing risk their job, a HUGE fine, and possible jail time to scan your reg card & snorkel another car. G luck
Old Jul 10, 2002 | 01:49 AM
driftracer's Avatar
Newbie
You will pass if your car is in good working order. My street ported motor passed easily with a new cat. It's not usually the street port that causes the problem, but these cars are old. A lot of things could be bad: TPS, cat, oxygen sensor, ignition, etc. Also make sure you warm up the cat by driving hard or rev the engine several times right before they put your car on a smog dyno. That helps a lot. Choosing a good smog station is important 'cause some of them are idiots. When they see an RX7, they automatically think trouble.
Old Jul 10, 2002 | 01:57 AM
DCmina's Avatar
crap I'm never gonna pass the test.
Old Jul 10, 2002 | 02:10 AM
osdesigns's Avatar
It depends on how the engine is "street ported." If the builder ports the engine and induce overlap, then it probably will not pass.
On the other hand, if the "street port" only lengthen the duration of the intake, by exdending the closing time and not modifying the opening time, there might be more chance of passing the smog.
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
