my NA tII project
Old Apr 10, 2011 | 03:29 PM
JWteknix's Avatar
my NA tII project
Well,
My buddy kevin(tubby) picked up a NA gxl w/ 55k original miles, bone stock bought it from the orginal owner, who said the car was too fast for him LOL. It sat from 2006. Interiors mint!! w/ back seat and no sunroof. He found the listing on CL and we went to take a look after a test drive I found it needed just basic stuff exhaust, brakes, and a few other odds and ends. Drove it a half hour back home with no problems put some gas in and went drove great.
So now the car sits until he can gets it registered. I was gonna pull it apart fix a leaking PD. I told him about removing the rats nest and removing everything to clean up the bay and simplify.
So while going thru my garage looking for stuff I noticed all of the parts that I no longer use or need. Its a whole tII swap minus turbo and manifold, and tII LIM.
I make the suggestion and he bites lol
Heres my project
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/goopy-street-motor-build-r-d-938383/
My other buddy Kevin has a similar project to mine but a level higher lol. Anyway I know he has my old LIM and a hybrid turbo, manifold, and DP sitting on the shelf for years with no need for it. I sent him a text and hes willing to part with it!!!
The turbo has a broken wastgate flap or arm he was telling me about, but other wise in good condition. Im going to contact Brian at BNR to see if he can fix it and look over the turbo.
So I'm goin to pick it up tomorrow and order some block of plates for the manifolds. I alread have a ported and modded TB, UIM, and elbow.
Im going to be running S4 tII ecu modded w/ rtek. 2.1.
stock 550cc tII primary injectores and 1000cc low imp secondaries and a walbro255
Ill be modding the tII LIM as per aaron cakes website.
http://www.aaroncake.net/rx-7/4PortLIMTo6Port.htm
Also throwing around the idea of some water to reduce temps and detonation. I figure like 10lbs would be ideal.
let me know what you guys think.
James
Attached Thumbnails my NA tII project-shop-004.jpg   my NA tII project-shop-005.jpg
Old Apr 10, 2011 | 04:11 PM
JWteknix's Avatar
The only thing I cant find is what wiring modifiactions will have to be done to use the tII ecu and manifold sensors with the S4 NA emission harness.
Old Apr 10, 2011 | 06:18 PM
SpikeDerailed's Avatar
This sh*t burns oil!
damn an 86 with no sunroof and 55k...jealous.
Old Apr 10, 2011 | 08:26 PM
JWteknix's Avatar
thanks man.. anyone else got some info for me?
Old Apr 11, 2011 | 10:16 AM
JWteknix's Avatar
I know theres info out there the links I have found are dead or temperarily down for maintenance...
Old Apr 11, 2011 | 03:41 PM
rotary everything!'s Avatar
86 fc3s base model
so, i dont have info 4 u but, im curious what r you doing with the n/a motor?
Old Apr 11, 2011 | 05:01 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The FAQ links are active. As is the archived thread in my sig.
Old Apr 11, 2011 | 07:42 PM
JWteknix's Avatar
It's being turbo'd...
Old Apr 11, 2011 | 07:49 PM
JWteknix's Avatar
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
this is the thread in the FAQ that is inactive.
I guess Im an idiot I should just modd the NA harness like I would a regular tII swap thanx
Old Apr 11, 2011 | 09:02 PM
JWteknix's Avatar
If anyone has a S4 LIM for sale let me kno or one thats already been ported to match the 6 ports
Thanks
James
Old Apr 12, 2011 | 02:40 PM
JWteknix's Avatar
Today we should be picking up the hybrid turbo, manifold and DP.
Still in need of a S4 tII LIM
Purchased block off plates for all the emissions from 2751Engineering
grabbed my UIM Assembly and pulled off all the useless **** gonna clean everything real nice get it ready to be swapped on.
Also grabbed my fuel rails. Modded the secondary to fit my 1000cc low imp american injectors
just need to clean everything up.
Old Apr 12, 2011 | 04:25 PM
JWteknix's Avatar
Well boys we got a better deal then I thought...
Under the impression were picking up a stock manifold and stock hybrid turbo..
Its basically a full HKS to4E kit, came with turbo w/ stock wastegate actuator, the wastegate flaps are missing, the coolant line to the LIM is gone. It also came with a HKS cast manifold and a small aftremarket DP.
Got it all for 375, gonna send it to Brian at BNR for a one over and flap repair, maybe some gate porting and upgraded actuator..
needs a bit of cleaning but its one hell of a deal.
Attached Thumbnails my NA tII project-tubby-turbo-001.jpg   my NA tII project-tubby-turbo-002.jpg   my NA tII project-tubby-turbo-004.jpg   my NA tII project-tubby-turbo-007.jpg
Old Apr 12, 2011 | 04:36 PM
sharingan 19's Avatar
Rotary Revolutionary
Nice! Makes me want too get my hybrid project underway
Old Apr 13, 2011 | 10:45 AM
JWteknix's Avatar
Mr. clean..
Old Apr 13, 2011 | 03:56 PM
JWteknix's Avatar
Got some more done, oil pans clean and ready for modding and paint.
I see aaron cake used the rear side of the oil pan for his turbo drain, is it possibly to run it to the front? Is there a reason for running it to the back verse the front?
Ill be getting an oil filter sandwich adaptor for feed and the coolant from unused nipples behind the waterpump and on the rear iron..
Attached Thumbnails my NA tII project-tubby-pan-001.jpg   my NA tII project-tubby-pan-002.jpg
Old Apr 14, 2011 | 09:41 AM
JWteknix's Avatar
gonna box everything and get it ready to ship
ECU - rtek, injector-KGparts, and turbo-BNR
I've emailed and phoned Brian at BNR and have yet to hear anything back...
Old Apr 14, 2011 | 09:58 AM
Sir, I need to get on your kind of unemployment
Old Apr 14, 2011 | 10:47 AM
JWteknix's Avatar
my builds almost done.. this is my friends stuff I gave him all my old stuff and said this is what needs to be done, im working on it for free and helping him out in exchange for some help finishing my car... but it is nice to get paid to do what I like for a change lol
Old Apr 15, 2011 | 05:00 PM
JWteknix's Avatar
Soo,
I finally got in contact with Brian at BNR and he tells me its too much work, theres not enough in it for him, and he wanted nothing to do with it..
I emailed 2 days ago and call yesterday leaving a detailed message in the morning and heard nothing back from him. So, I figure ill give it another try to contact him he answers and i told him I had emailed and called he didnt pay any attention to that..
I tell him the situation and tell him Ill send him some more detailed pictures...
He says "yah know I think I saw the pictures, I cant help. "
Soo I really couldnt believe his attitube, being last time I dealt with him he was very nice and helpful..
I need to find someone to do this relativly simple job.. Any suggestions??
James
Old Apr 15, 2011 | 05:15 PM
notveryhappyjack's Avatar
1 bar boost
Brian is a busy guy, I wouldn't take it too personal you know he could already have a bunch of things on his plate
Old Apr 16, 2011 | 04:03 PM
JWteknix's Avatar
So Tubby was smelling gas my first thought it was the PD but came find the smell was coming from the pump lid.
The middle men of this car for some reason, removed the lid and in exchange for the rotted stripped screws they replaced them with ones easily twices as long not even allowing the lid to be closed.
Removed them and the pump assembly cleaned the mating surface and gasket. sealed it all up with proper sized screws. and no gas smell since..
Old Apr 18, 2011 | 05:23 PM
JWteknix's Avatar
sent the turbo out to mono4lamar to fix the gate..
got the lim in got it all blocked off and filled with epoxy..
heres a shot of the modded and ported TB
Attached Thumbnails my NA tII project-lim-002.jpg   my NA tII project-lim-007.jpg   my NA tII project-lim-008.jpg
Old Apr 20, 2011 | 10:25 AM
JWteknix's Avatar
heres the LIM sanded and ready for porting..
thinkng of getting a tII front cover for oil drain. I kno aaron cake hasnt had any issues, but after speaking to goopy he kinda swayed me more towards the cover..
Located the correct 550 injectors to be sent to KGparts.
Attached Thumbnails my NA tII project-mani-003.jpg   my NA tII project-mani-005.jpg
Old Apr 22, 2011 | 07:32 AM
JWteknix's Avatar
Should be recievin the turbine housing back today.. It was repaired by mono4lamar..
Ill post pix when I get it... Gonna paint the turbo pan today.. need to order some intake gaskets from mazda...
Old Apr 22, 2011 | 08:27 AM
JWteknix's Avatar
sanded, cleaned and painted...
needs another coat but its good for now..
Attached Thumbnails my NA tII project-pint-pan-001.jpg   my NA tII project-pint-pan-002.jpg
