Power FC Changing the battery
Old Mar 30, 2011 | 10:03 AM
MLDoom's Avatar
Sorry if this is a silly question. Does changing your battery reset your PFC? Or does everything remain the same after I swap in my new battery and start the car up?
Old Mar 30, 2011 | 11:29 AM
thewird's Avatar
The map does not go away but the PowerFC learning may be reset which isn't a big deal.
thewird
Old Mar 30, 2011 | 12:42 PM
cewrx7r1's Avatar
Eye In The Sky
OK, I AGREE!
Old Mar 31, 2011 | 05:03 PM
Radial GT's Avatar
*BOV sound*
I was also wondering if I will loose my past year's map with my battery out while doing my rebuild!
Not that the map will be correct anymore due to porting, but at least I know it should idle decent enouph to work with it.
Thanks!
Old Mar 31, 2011 | 06:28 PM
the_glass_man's Avatar
Will u do me a kindness?
You will not lose your map because the PFC saves them into memory.
Old Mar 31, 2011 | 09:35 PM
MLDoom's Avatar
And to confirm is this the correct way to re-learn the idle?
Start Car, let it idle for approx 10 minutes before doing anything
Turn on air-con, let it readjust its idle and wait about 10 minutes
Turn on defroster (full heat), let it readjust its idle and wait about 10 minutes
Afterwards I can drive the car.
Old Apr 1, 2011 | 01:49 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
I thought it was rear defroster before AC but let the experts chime in!
Old Apr 1, 2011 | 02:21 AM
thewird's Avatar
Order doesn't really matter. They're 3 separate settings. IMO, if your car is running fine after battery change, don't bother going through the 30 minute procedure.
thewird
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
