Bad Injectors?
Old Jul 8, 2002 | 05:04 PM
gtrr4's Avatar
Bad Injectors?
What are some signs of bad/leaking Injecotrs besides the car flooding out?
Old Jul 8, 2002 | 08:27 PM
Icemark's Avatar
Running rich, or misfiring. Overheating cats, overheating engine.
Old Jul 8, 2002 | 08:34 PM
Ryde _Or_Die's Avatar
the engine runs hotter when it runs richer?
Old Jul 8, 2002 | 08:40 PM
Icemark's Avatar
With a stock exhaust... EGR tends to feedback too much when running rich and the pre-cat(s) heat up.
Old Jul 8, 2002 | 08:50 PM
Oh I gotcha. Thanks.
Old Jul 8, 2002 | 10:01 PM
gtrr4's Avatar
Well, my car does not flood. Once in a while I can smell gas when I really get on it. I have been told that I am running rich just for the simple fact of my backfiring. But I just think I got that down to a science though.
My delima is that around 6500 rpms, the car hesitates like the gas/air mixture is screwed up. This lasts till about 7200rpms, then it gets all of its power back. This is in 1,2, and 3rd gears.
Any ideas? Thanks
Old Jul 9, 2002 | 06:13 AM
gtrr4's Avatar
Anyone?
Old Jul 9, 2002 | 09:35 PM
gtrr4's Avatar
Any help would be nice.
Old Jul 9, 2002 | 09:38 PM
Icemark's Avatar
This is a T2 right???
Old Jul 9, 2002 | 10:23 PM
gtrr4's Avatar
no Ice, it is a 91 n/a
Old Jul 10, 2002 | 08:06 PM
gtrr4's Avatar
Helo me Please!!!!!
Jason
Old Jul 10, 2002 | 08:52 PM
Icemark's Avatar
the only thing I can think of is too check the operation of the VDI... it may be sticking
Old Jul 10, 2002 | 09:28 PM
injectors
my car keeps fouling out plugs really fast (in like 10-20 mins) and stalling out. then its hard to start back up when hot. someone told me bad injectors leaking onto plugs? its not even reliable enough to drive.
Old Jul 10, 2002 | 09:31 PM
by the way
besides the idle screw how else can i adjust air/fuel ratio so i know if its bad injectors or just running too rich?
Old Jul 21, 2002 | 09:33 PM
gtrr4's Avatar
I dont know if this would help any about my problem. Since the hesitation is so sparatic. The past two days its been very humid, and it really has been hesitating between 6k and 7k.
Jason
Old Jul 22, 2002 | 05:18 AM
gtrr4's Avatar
Any Ideas?
Old Jul 22, 2002 | 10:42 AM
blu_gxl's Avatar
well, for the hesitation i would check the regular stuff like, tps, and deffinately your boost sensor. mine had thae same kind of problem it's my boost sensor i believe i have a new one on the way to confirm. but, it used to hesitate just at 4k then it started to hesitate at 4k 5k then 4k 5k & 6k you get the idea, if you have a dmm i'd check the boost sensor on teh passenger shock tower facing the headlight. also could be a slightly misadjusted tps (doubtful) but it never hurts to check it any way.
just my 2 cents
james
Old Aug 11, 2002 | 05:50 AM
slidingsky's Avatar
hehe I remember when the bolt holding my fuel rail worked loose. I smelt gas and started freaking out, with good reason. just babbling
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
Frisky Arab
Sep 4, 2015 06:17 PM
