Megasquirt Q19 Question
Old Mar 15, 2011 | 10:52 PM
Owen's Avatar
Q19 Question
Searched and didn't find an answer, closest thing was this guys thread.
I was at 74 of the assembly manual and everytime I wired in one of those tiny transistors, I did a continuity check to make sure I didn't bridge the leads.
Well, pin 1 and the middle one showed continuity...took almost an hour to get the thing out. Now, on the board itself, there is still continuity. I used a razor blade and scraped between the pads but no use.
I found a schematic which refers to a fuel pump drive? But can't understand the symbology.
Is my board SOL? If I skip this recommended step, what can I do outside of MS to achieve the same thing?
thanks
Old Mar 16, 2011 | 08:54 AM
Aaron Cake's Avatar
Engine, Not Motor
R40 is only a 1 Ohm resistor, so most continuity testers will show continuity between the base and emitter of Q19.
Old Mar 16, 2011 | 08:28 PM
Owen's Avatar
I should've posted before I removed it, but thanks!
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
