Sudden power after overheating
Old Mar 11, 2011 | 01:01 AM
White Charisma's Avatar
[R.R.]
After slightly overheating (about 3/4 of the way up on the gauge) and letting it cool down for about 15 minutes, I can start it sometimes since it has the hot start issue.
When I do I need to pump the throttle to keep it from stalling, but once it's running it pulls much harder than when I start it normally. Is there anyone here with a similar "problem"?
If there is a way, I'd like to find the cause so I can harness that power all the time.
Mods:
Knightsport FCD
CorkSport 80mm turboback exhaust
Greddy BOV
Old Mar 11, 2011 | 10:18 AM
jjcobm's Avatar
Are you experienced?
it runs best before it goes out : )
Old Mar 11, 2011 | 12:44 PM
[R.R.]
Well in order to make my car overheat I have to disable my fan.
I first noticed it after a good drive and having it sit for awhile (that was before I fixed my cooling system)
Its pretty annoying and difficult to reproduce the effect.
I think it has something to do with my ecu getting stuck in open loop.
I replaced the o2 sensor to try to solve this but it didn't change anything.
Does anyone know what could be causing this?
Old Mar 11, 2011 | 01:53 PM
slitherz90gxl's Avatar
Resident Rotard
The hotter it gets the higher the compression is, right?
Since the seals expand?
Then again, on my old s5's engine I always joked that the housings were porting themselves because it was getting so hot.
Then again... it was cooling itself off with the exhaust gases.......
Edit: Are you actually trying to make your car overheat?
Old Mar 11, 2011 | 02:43 PM
duo2999's Avatar
Pabs
Originally Posted by slitherz90gxl
edit: Are you actually trying to make your car overheat?
same question is on my mind as well.
Old Mar 11, 2011 | 05:03 PM
w0ppe's Avatar
CC of L-Squared Shots
The seals expand making more compression; however, it's not a normal expansion. The expanding and contrasting of the metal leads to warping and further asplody issues...
Old Mar 11, 2011 | 09:15 PM
oinesra's Avatar
Measure to see if your water temp sensor is out of calibration.
Maybe is causing you to lean out on a hot start.
Old Mar 11, 2011 | 11:05 PM
[R.R.]
I'm not trying to get my car to overheat. I just experimented to see how I could replicate the results that I stumbled upon by accident.
I'll check the sensor tomorrow and see if thats the problem.
rx7shirley
Sep 2, 2015 02:11 PM
gtcd
30
Aug 19, 2015 02:44 AM
