starting problems
Old Mar 9, 2011 | 10:02 AM
joshprather93's Avatar
starting problems
ok so some times when i try to start the car it just clicks. i know your going to say the siliond (cant spell) but i think its something else cause i can get out of the car put it in gear push it about 9 inches and get in and it will start right up... ant help is appericated. thanks.
Old Mar 9, 2011 | 10:17 AM
not a lot of clicks just one CLICK.
Old Mar 9, 2011 | 11:58 AM
Hazard15301's Avatar
Rotor Junkie
It sounds like either:
A) Ignition switch. When you bump the key a few times does it fire up? Mine has this problem. It's really just a nuisance.
B) Bad starter/solenoid.
I've had both of these problems and they have the same symptoms.
Old Mar 9, 2011 | 01:32 PM
well the key is striped out..../ but i never thought about bumping the switch..... ill do that when i get in the car later if i have the problem..... i dont belive it is the starter it is new.... the switch is best idea thats probally why the PO installed a push button start. thanks..
Old Mar 9, 2011 | 05:03 PM
HAILERS2's Avatar
I had that symptom years ago. Was the brushes in the starter itself worn to a nub. I could take a hammer..........reach under the car and bang the starter.......get back in and start up. After too many times doing that I took the sucker apart and the carbon brushes were hardly even there. Done did wore out.
I could also do what your doing. Put it in fifth gear and push it fwd a couple of feet and then start it. Hard to do in parallel parking though.
Old Mar 9, 2011 | 05:50 PM
airquin23's Avatar
Team U.R.S
Um...corrosion on the battery terminals. A possibility also.
Old Mar 9, 2011 | 05:55 PM
jerd_hambone's Avatar
Bad ground at the starter?
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
