will advan sa2 or sa3 17x10 (rear) fit fd3s?
Old Mar 8, 2011 | 03:19 PM
anees's Avatar
amemiya7
hi there guys
i am planning to buy sum adavan sa2 or sa3 for my fd
i was wondering if i could fit 17 x10 to the rear without any modifications done like rolling up the fender
and what offset should i go with?
thanx
anees
Old Mar 8, 2011 | 03:30 PM
allrotor93's Avatar
+45 to +50 is always a safe bet.
Old Mar 9, 2011 | 11:31 AM
anees's Avatar
amemiya7
I am trying to give a staggered look
So i wana get more lip size like 2 inches in the rear
Does offset has anything to do with it
Old Mar 14, 2011 | 05:40 PM
anees's Avatar
amemiya7
Old Mar 16, 2011 | 07:28 PM
anees's Avatar
amemiya7
http://www.border-racing.com/fd3s_wi...mage-thumb.jpg
i am looking for sumthing like this
let me knoe wat offset should i go if i want sumthing this staggered
Old Mar 21, 2011 | 09:15 PM
zeroG's Avatar
That car has a widebody, so it's not going to be possible for you to get a rear lip that big on a stock body. It's impossible to tell you because every single wheel is different.
In general, the lower the offset and wider the wheel the more lip it has
Old Mar 22, 2011 | 08:04 AM
muibubbles's Avatar
Bubblicious DEF.
offset has everything to do with it when it comes to fitting...
judging from works rims, offset doesnt have anything to do with lip size, its generally on width of the rim i think 5zigens are the same...
for reference.. work xd9's...
if you look in the chart it tells you the size of the lip. its all the same size no matter what the offset is, but if you look at a different width, the size will vary
http://www.workwheelsusa.com/media/w....pdf:icon_tup:
Old Mar 22, 2011 | 11:29 AM
anees's Avatar
amemiya7
arite
so if i go with
17x9.5 or 17x10
than the lip size is more regardless of what offset?
Old Apr 8, 2011 | 10:08 AM
anees's Avatar
amemiya7
arite i found a set of
17x8 35 offset
17 x 9.5 35 offset
will they fit fine?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
