end play
Old Mar 6, 2011 | 01:35 PM
barnett87rx7's Avatar
lite rotary = easy push
end play
I replaced the bearing plate, thrust bearing, and thrust washer in the front stack and now have no end play, can I adjust it while in the car?
Old Mar 6, 2011 | 01:39 PM
arghx's Avatar
rotorhead
how did you measure the end play?
Old Mar 6, 2011 | 01:45 PM
Syritis's Avatar
exactly. how did you measure the end play while the motor is in the car?
Old Mar 6, 2011 | 02:46 PM
I tried to pry on the pulley with a screw driver and there was no movement what so ever
Old Mar 6, 2011 | 06:29 PM
Syritis's Avatar
well there should be any movement when the clutch already has the rotating assembly pushed forward.
Old Mar 7, 2011 | 03:57 AM
HAILERS2's Avatar
You can adjust the end play with the engine in the car.
Old Mar 7, 2011 | 04:32 AM
HAILERS2's Avatar
I'm not sure why your having a lack of play problems. It could be the bearing has fallen down. A easy way to check is to read the jpg attached and measure like the jpg says. Straight fwd and easy.
Old Mar 7, 2011 | 10:33 AM
Nick_d_TII's Avatar
^ Wish I knew that when I was building my first rotary. I took everything off to be sure the bearing hadn't dropped...
Old Mar 7, 2011 | 12:12 PM
RotaryEvolution's Avatar
Sharp Claws
with new bearings it could be now that the spacer is too short. there is different stamped spacers with different lengths to accodomate endplay variations. generally it's not an issue though unless you crushed the thrust bearings.
Old Mar 7, 2011 | 06:20 PM
Syritis's Avatar
this info is wrong. clutch doesn't apply load unless your holding the clutch pedal down.
not that being said. when I fried my thrust bearings. the car stalled while the clutch was depressed. so unless your having an issue like that, i'd suggest leaving well enough alone.
if you are having problems then pull the motor and sort it out on the engine stand. it's actually easier to do things the right way.
Old Mar 7, 2011 | 07:15 PM
HAILERS2's Avatar
Front covers, torrington bearings, spacer and the other bs can be done with the engine in the car. Once the new parts are installed don't install the front cover til you make the .0961 measurement shown in my first reply.
Can't get dial calipers in there. No room? Simple. Measure out .0961 on a piece of saftey wire/whatever and use that as the measuring gauge to determine if the parts/bearing has fallen down during assy. Then install the front cover..........check the .0961 once more and install the rest that was removed.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
