10th anny problem (eccentric shft)?????
Old Mar 6, 2011 | 09:28 AM
loudazzrx7's Avatar
C-town Hustler!
Ok so I picked up this 10th anniversary up back in 09.No problems but the clutch was slipping.When taking the tranny out I noticed everything had been wiped down and cleaned.Only had a week before I replaced the clutch.The rear main seal was leaking.Did not think much about it and of course put another seal in with the clutch.
About 2 or 3 months later the rear seal started leaking again!!.I let it go for a while this past summer I took the tranny back out again to replace the seal and noticed the eccentric shaft had a lot of play in it(side to side.Looks like its knocking the seal.I put another seal in and this time it lasted all of a hour before it started leaking again.
I was told to try and tighten it up from the front bolt and I did that but it did not help.I talked to a rotary shop here in Maryland and they never heard of the eccentric shaft hitting the seal.Any ideas would be appreciated.Just cant afford a rebuild right now.
Old Mar 6, 2011 | 03:04 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
The e-shaft should not be moving side to side. Does the engine even run? Sounds like major internal bearing wear/damage.
Old Mar 6, 2011 | 03:14 PM
SpeedOfLife's Avatar
rotors excite me
^^^ agreed, it definitely shouldn't. how MUCH is it moving side to side?
Old Mar 6, 2011 | 05:50 PM
2slow4stock's Avatar
The waiting game......
It shouldn't move side to side, end of story. But when your say side to side you mean left and right, but not up and down? Or up and down and side to side.?
Old Mar 6, 2011 | 09:08 PM
loudazzrx7's Avatar
C-town Hustler!
Up and down,and yes the motor runs and runs strong,before clutch started slipping,was running high 13s in the 1/4.
Old Mar 6, 2011 | 09:46 PM
rotors excite me
alright enough with the up/down/left/right/side/side ****.
Which is it?
Old Mar 6, 2011 | 10:15 PM
Andy87t2's Avatar
the inside of the stationary gear would have to be worn or something wouldnt it? or the gear would have to be loose? weird issue, good luck in solving it.
Old Mar 6, 2011 | 10:23 PM
drifting in drifting's Avatar
How is your oil pressure.Sounds like bearing clearance.
Old Mar 7, 2011 | 12:12 PM
loudazzrx7's Avatar
C-town Hustler!
from your drawing its # 1 going in and out.Anyway to try and correct this without yanking the motor out and doing a rebuild?
Old Mar 7, 2011 | 12:16 PM
RotaryEvolution's Avatar
Sharp Claws
#1 is endplay and a small noticable amount is perfectly normal.
the #1 issue i find with the rear main seal is that they like to spin inside the rear stationary gear. if the seal feels loose going in, i wipe everything down and apply some sealant to the rear main seal before tapping it into the rear gear housing, let it cure for about a day before starting the engine.
if this is the case you can verify it by spinning it inside the carrier with your fingers while installed.
next issue is make sure there isn't a large lip worn into your flywheel/rear counterweight where the seal rides on the surface, also be sure you aren't cutting the seal when installing the flywheel, add some bearing grease to the inside lip of the seal, do NOT install it dry. also do not clean the flywheel seal surface with a wire wheel, it is very likely to leak through the tiny divots that the wire wheel leaves behind, a better alternative to cleaning the surface is using some 800 grit sandpaper with a circular motion.
Microtech
Sep 27, 2015 09:28 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
