Megasquirt Tuner Studio help
Old Mar 4, 2011 | 12:07 PM
gfd263's Avatar
GA Tuner Studio help
So I am getting this set up. I need fuel only at the moment. Do I need no skip pulses and rising edge?
Old Mar 4, 2011 | 12:58 PM
gfd263's Avatar
I am using negative side of leading coil to trigger the tach, so I have it listed as 1 coil.
Old Mar 4, 2011 | 03:04 PM
muythaibxr's Avatar
MegaSquirt Mod
There should be a fuel-only setting. Just use that for now until you're ready to run ignition. Skip pulses just gives the RPM on cranking a chance to become stable before fuel is squirted (if you're in fuel-only mode). Triggering off the coil negative, I'd use 1 or 2 for that. Any more and the startup will take considerably longer.
Ken
Old Mar 6, 2011 | 12:34 PM
gfd263's Avatar
Ken, I am not receiving a tach signal. The tach worked before fine off the negative side of the coil before I updated firmware. I have tried rising and falling edges. Any ideas?
Old Mar 6, 2011 | 03:26 PM
gfd263's Avatar
Works now??? Have no idea why, did not change a thing. It just started working.
Old Mar 6, 2011 | 07:18 PM
muythaibxr's Avatar
MegaSquirt Mod
Did you reboot the MS before it started working?
Ken
Old Mar 7, 2011 | 03:38 PM
gfd263's Avatar
I think it was because I had megatune and tunerstudio both open at the same time. I don't know. I had rebooted the ecu several times. That is the first rule of electronic repair...Start over with the on switch.
I sent the injectors off for ultrasonic cleaning today. I ordered a new rectifier for the alternator as well. I hope to have it back together early next week. In other words, I will leave you alone til then.
Thanks
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
93FD510
Oct 1, 2015 02:00 PM
fd3CB
SevenStock Archive
Sep 11, 2015 11:12 AM
