Would you recommend running an t2 swap on a n/a rear end (searched)
Old Mar 3, 2011 | 01:23 PM
lunardeathgod's Avatar
I'm considering all the possibilities before I start buying all the parts needed for a t2 swap, and I just found out you can run a na rear end with a t2 motor and tranny with a mazdatrix drive shaft. Now what i am asking is that is it worth it? Will it break on me down the line? Or should I just keep waiting till I come across the t2 rear end components.
Old Mar 3, 2011 | 01:27 PM
Spirit-RE's Avatar
search. For the most part the n/a rear end is garbage when power is pushed through them, however a few guys have had luck with them.
What are you using the car for? If your going to be drifting or launching, get a turbo rear end.
Old Mar 3, 2011 | 01:36 PM
HAILERS2's Avatar
I've been running a 87 non turbo car with a stock turboII engine/transmission with non turbo rear end for over five years with no problems. It's a daily driverr type car. Mazdatrix driveshaft.
I prefer that car to my stock 87 TurboII car.
Old Mar 3, 2011 | 02:18 PM
rx7racerca's Avatar
There seems to be a lot of varied opinion on this, but ~300hp seems to be the point that the NA diff doesn't hold up well past - below that, you may get years of use out of it. Do you at least have an LSD diff? If not, I'd go looking for a TII diff and axles anyway, no point having power and using it to light up one tire at a time.
Old Mar 3, 2011 | 03:23 PM
Well i tend to use it as a daily driver with some autocross fun. I dont plan on upgrading it any more after that. I just want to have a turbo, I dont think there is a point to have that much power since I wont be using it most of the time. also is this the drive shaft there talking about... http://www.mazdatrix.com/getprice.asp?partnum=2691-799
And I dont have a stock LSD, would that be something I should look into?
(and i did search, but I wanted someone's opinion on it.)
Old Mar 3, 2011 | 03:50 PM
rx7racerca's Avatar
If you're autocrossing it, I'd say yes, get an LSD, S4 na or TII - even my NA with bolt-on mods is way too easy to light up the inside tire autocrossing.
Old Mar 3, 2011 | 10:22 PM
RotaryRocket88's Avatar
Top Down, Boost Up
So far 2.5 years with an NA LSD & a stock turbo @ 12 psi. Daily driven and occasionally launched when I get the urge.
Old Mar 4, 2011 | 09:12 AM
dimitry04's Avatar
awe but who doesn't love the one tire fire. =] i have it on my truck and my 7. it sucks havin that
Old Mar 4, 2011 | 12:34 PM
j9fd3s's Avatar
Community Builder
yes, run the NA rear, IF it breaks than swap in the turbo diff. this is the easiest and simplest way. its a TON of work to change everything out just because it *might* break someday.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
