how long does a turbo last?
Old Jul 7, 2002 | 11:29 AM
ninjaboy's Avatar
whats up? im looking at a rx-7 turbo II, it has 150,000k on itand i was curious as to how long turbos usually last before they need replacing and if theyre expensive.
thanks
Old Jul 7, 2002 | 12:05 PM
eViLRotor's Avatar
Brother of the Rotary
Well, with a 150K you're getting up there with a turbo rotary, but by no means too much. So much depends on how the car was maintained or modded. It could still run a long time.
If you do a search you'll find lots of info about longevity and what to look for when buying a TII!
And yes, engine/turbo rebuilds are not cheap!!! Were talking thousands of $$$$....
Old Jul 8, 2002 | 10:42 AM
ninjaboy's Avatar
it looks like this car has been taken good care of. a friend of mine told me i should be able to put about 300k on it before it dies. hopefully it does, because i dont have big coin right now for a rebuild.
Old Jul 8, 2002 | 10:56 AM
Look on the spark plug side of the motor where the housings are all together. Look for signs of gooo or oil dripping from between the housings. Mild ammounts of Gooy stuff is OK but oil could mean the oil seals are going. The Goo starts getting pressed out of the side of the motor, and eventually will lead to oil leakage.
BTW, the car will run fine with any of these things, it may just need oil every once in a while.
You can check the turbo by checking shaft play. all you gotta do is take the airbox and rubber pieces off. Takes me about 5-10 minutes to get down there. I'd say any play more than .5mm is a little much. Saab guy told me this hope it helps!
Old Jul 8, 2002 | 11:28 AM
diabolical1's Avatar
eliminate friction, and ... who knows???
Originally posted by ninjaboy
... a friend of mine told me i should be able to put about 300k on it before it dies. hopefully it does, because i dont have big coin right now for a rebuild.
well, don't get me wrong. i wish you nothing but the best, BUUUUUT ... i have never heard about a T2 (or any other engine for that matter, rotary or piston) lasting for 300K miles before their first rebuild.
is it possible??? i suppose anything is "possible" ... but if i were you, i wouldn't get my hopes up too much.
Old Jul 8, 2002 | 12:19 PM
kleach18's Avatar
Just Looking Around
I've heard of rotary's lasting till 300k! Just a 12A, now I've seen a 13b N/A last to about 250k. So yeah it can/has happened. I've never really heard of a TII lasting that long. And there are a couple of piston's that I have seen with my own eyes that had about 300 K miles, it was a toyota pick-up, one of the old 4X4's from like the mid to late 80's. It ran great until he rolled it like 6 times then drove it home and retired it!
kleach
Old Jul 8, 2002 | 12:36 PM
jimmyv13's Avatar
Round&Round not Up&Down
Re: eliminate friction, and ... who knows???
My Dad's 88 Honda Accord LXi has 329K miles and he bought it new in December of 87. Original motor, 2nd clutch, anything is possible.......
Old Jul 8, 2002 | 04:18 PM
BlackRx7's Avatar
Daily Domestic Killer
my moms 94 grand marqui has 245k and the only thing replace was the tranny at 200k, it still runs strong. just goes to show if you maintain a car properly it might as well last forever...................this doesn't mean shifting at the redline all the time....................
Old Jul 8, 2002 | 04:20 PM
WonkoTheSane's Avatar
Green Flameless
that one guy's volvo just passed the 2million mile mark, he had one engine rebuild at 600k
Old Jul 8, 2002 | 05:10 PM
well ... i guess now i've heard of it. so i stand corrected.
i still wouldn't put money on a T2 lasting that long, but at least it puts back some of the air i deflated from ninjaboy's balloon, right?
sorry ninjaboy ... i'm just a student of defeatism, but i'm trying to reform
cristoDathird
28
May 30, 2019 08:47 PM
Machupicchu
Aug 17, 2015 08:27 PM
