Power FC Power FC and O2 Sensor
Old Feb 26, 2011 | 09:18 PM
Zatzy's Avatar
My question is can you sub out the o2 sensor with the power FC for a wideband o2 sensor instead. Is there any reason to keep the stock O2 sensor? Also are you able to connect the wideband to the power fc if the reading is still necessary?
Old Feb 26, 2011 | 10:16 PM
cewrx7r1's Avatar
Eye In The Sky
Do not fully understand your question, but here is what you can do.
You replace the stock O2 sensor with a WB. Connect the 0-1V output to the stock WB connector single wire. This is needed only if you are running O2 FB. Run the WB 0-5V to the DATALOGIT.
But due to the higher heat at this position, the sensor might overheat.
Old Feb 27, 2011 | 04:39 PM
cewrx7r1's Avatar
Eye In The Sky
The bold red print should have been O2 sensor .
Old Feb 27, 2011 | 09:11 PM
Zatzy's Avatar
ya thats all i meant. just didnt know if I had to run the stock 02 sensor or if i could just use the WB instead and have the power FC read from it. didnt want to weld another bung in haha
streetlegal?
Mar 17, 2022 02:46 PM
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
