AEM EMS Area is for discussing the AEM Engine Management System!
AEM AEM into FC
Old Feb 24, 2011 | 06:08 PM
just startn's Avatar
Turbo vert
AEM into FC
Has anyone installed AEM Universal into the FC? I searched and did not find the answer i was looking for. Since they dont make a specific ECU for the FC (that i have seen) then you would have to get the universal one. Is there any tricks you have to do to get the car and ECU understanding each other? Im trying to figure out if this ecu is exactly what i want to buy. If somone gave me a brief run down on it and a 13bt in a FC that would be greatly appreciated. Also if anyone can get them for a good deal lmk the price and what its including. THanks, Russ
Old Feb 24, 2011 | 08:20 PM
D Walker's Avatar
I just used an FD ecu. New connectors are easily and relatively cheaply available. I "believe" you can also use a 1G dsm box, one of the Honda boxes, etc. and it will work fine. If you like, feel free to pm me for my number and I can run down exactly what I did.
Also, if you happen to have an S5 FC the AEM ECU will plug into the connectors and you only need to swap a few pins around.
Old Feb 24, 2011 | 10:50 PM
arghx's Avatar
rotorhead
The Banzai Racing power FC adapter harness will work with an AEM EMS if you want the most plug-and-play solution.
Old Feb 25, 2011 | 01:48 AM
C. Ludwig's Avatar
www.lms-efi.com
If you're interested in using AEM, I would wait for the new EMS-4. Specs look to be quite the nice box at a low cost.
Old Feb 25, 2011 | 08:42 AM
D Walker's Avatar
^^^^^ This is true, but will not be exactly plug-and-play. The EMS-4 also holds a lot of promise for ATV's and snowmobiles modded past the ability of the stock ECU to control. Have a friend chomping at the bit to put one on a race quad.
Old Feb 25, 2011 | 09:45 AM
C. Ludwig's Avatar
www.lms-efi.com
Depends on who you're getting it from and their ability to build the appropriate harness.
Old Feb 25, 2011 | 12:30 PM
D Walker's Avatar
Ha! Yes thats true!
Old Feb 25, 2011 | 03:14 PM
Turbo vert
All my harnesses are custom. i have no such thing as "plug and play". I was looking at them TEC3r's. theres 2 for sae for a decent price
Old May 15, 2011 | 09:25 AM
EB Turbo's Avatar
I put a 30-1800 in a turbo II swapped convertible. I used the FC Cas, FD water and air temps, FC tps, FC leading coil, FC modified trailing coil, GM MAP. I used the #4 plug from the car. I just hastily swap a couple of pins around and then I made my own engine harness. Everything went pretty easy. No major problems.
EB Turbo
Old Oct 8, 2011 | 10:24 AM
mymmeryloss's Avatar
Oilfield Trash
Is there anyone making plug and play harnesses or is it something u have to figure out yourself?
Old Oct 10, 2011 | 09:57 AM
EB Turbo's Avatar
Banzai racing makes an adapter to put a Power FC ecu into FC's. Just buy their kit and plug in the AEM EMS. It will work just the same. You will still need to modify the trailing coil igniter to get the trailing coils to fire properly.
EB Turbo
Old Oct 10, 2011 | 11:58 AM
Oilfield Trash
That's the info I needed right there! Thanks a lot!
Logan Reinisch
44
Sep 17, 2018 12:20 PM
eplusz
15
Oct 7, 2015 04:04 PM
