Wheel width = tire width???
Old Jul 6, 2002 | 11:53 PM
E6KT2's Avatar
I am really looking for some sort of table or database that shows what size tires fit what width rims. I haven't narrowed down which rim I want yet, so I am just looking for some kind of general guide.
ex. Will 275 width tires fit a 7.5in rim?
Anybody got a link?
Old Jul 9, 2002 | 12:42 PM
Matlock's Avatar
Excellent ?! Bump ^^^^
Old Jul 10, 2002 | 12:19 AM
maxcooper's Avatar
WWFSMD
Look at the spec sheets for the tires you are considering and the rim width range will be listed for each size. You can find the spec sheets for many tires on TireRack.com or the tire manufacturer's web site.
275s will not work on 7.5 wheels in general.
-Max
Old Jul 10, 2002 | 03:49 AM
duboisr's Avatar
275 tire=9in to11in rim -see the tire and rim association book
Old Jul 10, 2002 | 06:00 AM
SleepR1's Avatar
Generally you want the rim width to be 90% of the tire section width for ideal tire sidewall support.
Convert mm to inches by dividing by 25.4, so 275 mm converts to 10.8 inches (rounded to the nearest 1/10 inch). 90% of 10.8 inches is 9.7, so this means you could run either a 9.5 or 10 inch-wide rim for a 275-mm wide tire.
This general rule of thumb will work for any tire size, and you won't need any books, just a calculator
Old Jul 10, 2002 | 02:34 PM
peejay's Avatar
Old [Sch|F]ool
I thought for best handling you wanted the widest rim that your tire would fit over? I know it looks goofy but it provides for zero chance of the tire buckling under.
Old Jul 10, 2002 | 02:44 PM
SleepR1's Avatar
Yeah...that too
Old Jul 10, 2002 | 07:40 PM
RETed's Avatar
Each tire manufacturer has a chart of recommended tire widths.&nbsp This would be the BEST place to check.
-Ted
Old Jul 12, 2002 | 01:56 AM
Manntis's Avatar
add to cart
To prevent tire buckling under run low profiles with stiff sidewalls. That's the majority of the handling benefit of low profiles
Old Jul 14, 2002 | 03:11 AM
peejay's Avatar
Old [Sch|F]ool
But when you run super-short sidewalls like that, you lose forward traction and the traction curve is too peaky. (grip... grip.... OH ****!!!!)
Call me old fashioned but I like to get the car up and slide all four tires around the corners... anything less feels like I'm not doing enough Hmm maybe I should look for some bias-plies for my next set of track tires?
Old Jul 14, 2002 | 09:40 AM
SleepR1's Avatar
Yeah you have to find the right balance. I find that 255/40-17s on 9 x 17s work very nicely in that regard...
Old Jul 14, 2002 | 11:06 AM
peejay's Avatar
Old [Sch|F]ool
That's the thing... balance...
That's an awful small sidewall IMO, but then your roads probably aren't as bad.
Old Oct 12, 2002 | 10:05 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
tire conversion calculator.
this links you to an excellent calculator.
http://www.miata.net/garage/tirecalc.html
