Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Detailed pics of 1jz/2jz motor mounts/mounting locations
Old Feb 3, 2011 | 07:05 AM
RotaSpinna69's Avatar
TX Detailed pics of 1jz/2jz motor mounts/mounting locations
I'm actually swapping in a RB25 from an old project into my FC3S, but would like to see some more detailed pictures of motor mounts or the actual custom mounting locations done to the stock subframe.
Here is a picture of the TECH2 kit...
I just don't see exactly how that works. Do they remove the factory subframe? I do NOT want to do that.
Any info/help would be great.
Thanks,
Andrew
Old Feb 3, 2011 | 11:24 PM
tecknix's Avatar
If it spins, keep blowing
Looking forward to your rb swap - If you look, all ls/jz swap remove the subframe/cradle and simply make their own.
Good luck and hopefully you'll provide a ton of details!
Old Feb 3, 2011 | 11:33 PM
blue87t2's Avatar
you should not have to remove the sub frame; the large bracket in the lower portion of the picture is the transmission support/brace/adaptor. the big "u" shapped thing looks like you bolt into the subframe were your original mounts would go and then you would bolt the supplied mounts to it and install the engine like normal. but that's at first glance of the pictures
interested how it would preform compared to a 1jz, good luck.
here is my build up thread, http://www.2jzswap.com/vbulletin/showthread.php?t=2600
Old Feb 4, 2011 | 07:44 AM
THANKS! But, I simply do NOT want to build a subframe. This is going to be a dedicated track car, so some rules don't allow it.
I just don't understand the "U" shape haha. I've seen alot of threads for swaps and they have just created extended mounts. I guess the "U" is just for reinforcement. That is for a 1/2JZ kit anyways...
I will definitely be checking out your build!
Thanks,
Andrew
Old Feb 4, 2011 | 12:22 PM
blue87t2's Avatar
Thanks,
Andrew
i haven't updated that thread for a while, im single turbo now.
i thought it was strange to that "u" shaped piece, but thats the only thing it could be
David Hayes
13
Sep 5, 2022 12:45 PM
