Anyone seen a FC Rear Subframe bushing how-to?
Did some searching, but didn't come up with anything in the form of a how-to or install. Especially for the solid or Derlin bushings. Does the subframe have to be removed completely? Anyone care to chime in?
Thanks,
Andrew
Thanks,
Andrew
It makes it 1000x easier with the sub-frame out but its not 100% nessisary.
Its pretty straight forward tho, remove old bushings(probably cut/burn out)
And replace with new. Took me about 20 min with the frame out
As long as the new bushings do not have to be PRESSED in, I'll be fine. I am replacing the front diff. bushings so I thought I'd do the bushings with the subframe hanging down.
Thanks,
Andrew
Thanks,
Andrew
Trending Topics
GrossPolluter
Aug 15, 2015 10:32 PM
