AEM EMS Area is for discussing the AEM Engine Management System!
AEM which injector resistors to use with aem
Old Jan 12, 2011 | 10:32 AM
indio84's Avatar
as title says, which resistor is best to use with the bosch 1680 injector running the aem unit.
Old Jan 12, 2011 | 11:14 AM
TonyStarkz's Avatar
Built to race!
I would prefer a driver (AEM P&H driver, FJO, etc) over a resistor any day. I also had success using a honda resistor box albeit not on an RX7.
Old Jan 12, 2011 | 07:48 PM
D Walker's Avatar
I am using a Mitsubishi 4cyl resistor pack, but there are others available. I know Rotary Aviation had some they were selling that supposedly were very good.
Old Jan 13, 2011 | 05:50 AM
indio84's Avatar
hey d walker, I know the fjo unit is pretty good price but a little more info on your setup of the mitsubishi injector driver would be interesting to see.
or which mitsubishi unit exactly?
and what is your setup?
Old Jan 13, 2011 | 10:30 AM
TonyStarkz's Avatar
Built to race!
More than likely the one out of an eclipse. Just as simple as the honda one with a different look lol
Old Aug 30, 2011 | 01:50 AM
T-Rex88's Avatar
Do you have to use a resistor with the Aem ems? Do the only run LI injectors not a fan of using any resistors...
Old Mar 21, 2013 | 06:16 PM
rexset's Avatar
Racing Mechanic
how can you connect it
for the price seem to be the best deal
Take a look of this
http://www.ebay.com/itm/Mitsubishi-Eclipse-Gst-Gsx-2g-Fuel-Injector-Resistor-Pack-Talon-Tsi-95-99-4g63-/121065817535?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AMitsubishi&hash=item1c3015c5bf&vxp=mtr
Old Apr 5, 2013 | 08:05 AM
rexset's Avatar
Racing Mechanic
Old Apr 5, 2013 | 11:48 AM
EB Turbo's Avatar
You can either hardwire the resistor pack into the engine harness or you can make a PnP adapter for it. The easiest place to get access to the Injector wires is at the ECU.
EB Turbo
Old Apr 5, 2013 | 11:58 AM
rexset's Avatar
Racing Mechanic
So its the same that the aem inj driver?
Old Apr 5, 2013 | 05:16 PM
EB Turbo's Avatar
It does the same thing but the AEM uses a different connector.
EB Turbo
Old Apr 5, 2013 | 09:05 PM
rexset's Avatar
Racing Mechanic
How can i get the pinout?
Witch one you recomend to buy?
Old Jun 12, 2013 | 03:26 PM
rexset's Avatar
Racing Mechanic
what do you think about this?
http://www.ebay.com/itm/BOSCH-160LB-1700CC-160-LB-FUEL-INJECTOR-HIGH-IMPEDANCE-EV1-CONNECTOR-W-HARNESS-/290883472206?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43ba018b4e
I have a cuple of 1680cc bosch low impedance fuel injectors but they are leaking , so can i buy this ones and no use the resistors?
Old Jun 12, 2013 | 06:59 PM
EB Turbo's Avatar
Yes, those will work. You should get battery offset tables with the injectors and you can input that data directly into the ECU.
EB Turbo
Old Jun 12, 2013 | 07:08 PM
rexset's Avatar
Racing Mechanic
Excelent!!
Thanks Mate!!!!
I will
But firts i need to deal with the wastegate problem
Hope that i will solve that this weekend or next week
Old Oct 22, 2013 | 06:55 PM
rexset's Avatar
Racing Mechanic
Wastegate problem fixed
I went with a single Tial V60 , is the best!!!!
Now i check my injectors and they are damage so i need to buy a couple new
The best will be the same ohm that the original
Im thinking about the 2000cc ones or 1700cc
Old Oct 23, 2013 | 10:34 AM
EB Turbo's Avatar
How much power are you planning on making?
EB Turbo
Old Oct 23, 2013 | 10:39 AM
rexset's Avatar
Racing Mechanic
400 whp~430whp
Now im running 4 850cc with an Nipon denso supra fuel pump
Old Oct 23, 2013 | 10:41 AM
EB Turbo's Avatar
400 whp~430whp
The 850s are stock secondary injectors?
EB Turbo
rexset's Avatar
Racing Mechanic
Yes
They are
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
