Should I install NOS
Old Jul 4, 2002 | 04:26 AM
Richierich's Avatar
crazy canuck
I just bought a Zex nos kit for my 93 RX-7 with a Apex IHI turbo kit. I have a f-con that works great with this set up. The power is good, but not great. How risky is installing this kit? The engine is new from japan with 4000 miles( witha street port). With the smallest jet (55HP) what are the chances of blowing my new engine?
If anyone has any experience with nos, please let me know.
PS I was thinking of spraying it on my Peter Farrell intercooler if it is to risky(is that bad?)
Old Jul 4, 2002 | 10:18 AM
forcefed7's Avatar
Re: Should I install NOS
The intercooler choice won't really make any difference with the nitrous. I would make sure you handle on your A/F ratios on just turbo first before you use it.
Old Jul 4, 2002 | 11:20 AM
Richierich's Avatar
crazy canuck
the A/F are good for the turbo
Old Jul 4, 2002 | 05:29 PM
dellorto7's Avatar
Re: Re: Should I install NOS
keep it low 11's high 10's.
Old Jul 5, 2002 | 02:39 AM
fastrotaries's Avatar
W. TX chirpin Monkey
If you got enough fuel, the amount of NOS shouldn't wear on your motor all that much. Unless you use it at every stop light.
Old Jul 6, 2002 | 07:11 AM
osdesigns's Avatar
Lets see.... NOS stands for Nitrous Oxide System, and you have ZEX... So you probably won't be shooting NOS into your engine :-p
Spraying "nitrous" on your intercooler could improve its cooling over the ambient temperature, thus decreases the chance of going into detonation. Make sure you don't spray "wet fogger mixture" onto a ignition source.
If your air to fuel ratio is within the safe margin, you probably won't blow your engine from the ZEX nitrous system. ZEX systems uses a computer controller to increase fuel mixture so you should not run any leaner than what you are already running.
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
Enzo1944
Sep 6, 2015 08:57 AM
