AEM EMS Area is for discussing the AEM Engine Management System!
AEM Sensors
Old Jan 2, 2011 | 03:37 PM
indio84's Avatar
Sensors
I was looking for fuel press, map and air inlet sensor.
1.first question is having the AEM pnp I'm guessing i won't need the air inlet sensor, stock system already has one or am i wrong?
2. does these sensor work ? are they any good
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Jan 2, 2011 | 06:59 PM
D Walker's Avatar
I cant view the links directly at the moment, but I use only AEM sensors these days, as they are really the best value for dollar spent. I can supply them if you want, just PM me.
EDIT also, no you do not need an IAT, and as far as a MAP sensor I use the AEM 5 bar Stainless Steel sensor, although there is a brass one available if you want to save a few bucks. I have the part numbers at the shop if you want.
Old Jan 3, 2011 | 08:00 AM
indio84's Avatar
yes these links are for the brass type sensors. all of them are brass.
so they do work? it saves me a bit more money.
what all do you advice i should datalog?
Old Jan 3, 2011 | 08:05 AM
indio84's Avatar
send me the part number thnx
Old Jan 3, 2011 | 10:54 AM
C. Ludwig's Avatar
www.lms-efi.com
Use an IAT but don't spend that much.
http://www.bmotorsports.com/shop/pro...roducts_id/400
Direct fit coolant temp sensor with GM calibration.
http://www.bmotorsports.com/shop/pro...oducts_id/1598
Old Jan 3, 2011 | 02:54 PM
indio84's Avatar
holy crap, that is cheap.
anyone tried these sensors?
do they have any sensor for fuel pressure?
Old Jan 4, 2011 | 11:27 AM
C. Ludwig's Avatar
www.lms-efi.com
We use the sensors from Ballenger all the time. You probably won't find a less expensive pressure sensor than the AEM unit.
Old Jan 4, 2011 | 11:29 AM
D Walker's Avatar
Agreed ^^^
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
